molasses
44 replies to this topic
#1 _ljxu1torana_
_ljxu1torana_
Posted 28 March 2016 - 11:13 PM
i have heard that molasses is very good as a rust removal and preventer.has anyone tried this before.i would say it might stink a bit.
#2 Ice
  • 15,221 posts
Posted 29 March 2016 - 12:05 AM
Yes And yes depends on how bad the rust is you have to soak the parts longer
there is a youtube clip somewhere on the web
#3 _ljxu1torana_
_ljxu1torana_
Posted 29 March 2016 - 12:36 AM
hi gene i saw the ad on you tube he is from aussie with a lc torana.
#4 dattoman
Posted 29 March 2016 - 01:08 AM
Try citric acid
25kg per 1000L
$30 bag
#5 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 29 March 2016 - 03:04 AM
Have a molasses dip on the go at the moment .Have a fuel tank that I was going to throw out because it has that much gunk in it .The sender has been in the mix with the tank for just 6 days and it is working very well .Used a 1000 litre Ibc or plastic bulky what ever you want to call it .Cut the frame off at 600 litre mark with grinder .Cut bladder with a hand saw at the same height .Put 40 litres of molasses ($60.00)in it and mixed in 400 litres of water with a big stirer I have made.Sunk the tank in the mix and then put the top part of the bladder I cut off over the bottom part .Nice compact unit and no smell at all  .Surprised at how well it is working .Shall throw up some pics when I can take them .
#6 Bernie
Bernie
  • 301 posts
Posted 29 March 2016 - 03:29 AM
Attached File  IMG_3167.JPG   330.78K   9 downloadsAttached File  IMG_3168.JPG   80.97K   10 downloadsAttached File  IMG_3169.JPG   156.7K   9 downloadsAttached File  IMG_3170.JPG   108.56K   10 downloadsAttached File  IMG_3172.JPG   58.62K   9 downloadsAttached File  IMG_3173.JPG   110.04K   9 downloadsAttached File  IMG_3174.JPG   98.78K   10 downloads
Have some here I forgot about .That is under a week .Will pull the tank out later this week and water blast it ,put a camera up inside and check it out .Then stick it back in .You can get an idea of how much crud is in the tank from the photos  ,
Bernie
#7 Bernie
Bernie
  • 301 posts
Posted 01 April 2016 - 08:25 PM
Attached File  IMG_3189.JPG   78.85K   11 downloadsAttached File  IMG_3190.JPG   141.39K   9 downloadsAttached File  IMG_3191.JPG   145.32K   10 downloadsAttached File  IMG_3192.JPG   122.57K   9 downloadsAttached File  IMG_3193.JPG   76.31K   9 downloadsThis is the result after 10 days submerged in the molasses
#8 lctriples
lctriples
  • 414 posts
  • Name:paul
  • Car:LC 2 door, HR prem wagon
Posted 20 April 2016 - 10:11 PM
Bernie, how is tank and sender coming along? Just wondering if concoction is safe for plastics/rubbers ect or do you need to remove from anything you are "molassasing" Cheers and thanks for taking the time to post photos up as always wondered how this method worked.
#9 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 21 April 2016 - 06:27 AM
You can see the high tide mark where l had this partially submerged in a molasses bath.
I wouldn't worry about rubber or plastic although aluminium may get eaten.
P1010056-2.jpg?t=1290546341
#10 Bernie
Bernie
  • 301 posts
Posted 22 April 2016 - 08:03 PM
Tank is good ,Sender was shagged but I put it in anyway .Washed the tank out a couple of days ago ,put it back in as I think it may have had a bit of air in it still and I put it back in to get the last of it off .Hoping to remove the tank from the mix and will seal it tomorrow with KBS .Had the O ring in the mix and it is still ok .Will pull the sender apart and see what it may have done to the internals .Will start a new post and put it all up so it is out there for others  .
Bernie
#11 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 22 April 2016 - 08:29 PM
thanks for that Bernie, will keep an eye out for next post.
#12 Shiney005
  • 9,829 posts
Posted 10 July 2020 - 09:49 AM
I made up a bath with an IBC similar to Bernie's setup as I had a whole motor to do. It had been left out in the weather for a year and I wanted to see what I could salvage.
Once everything was submerged I picked it up with the forks and put it out of the way under the shearing shed as it was going to be working for five weeks or so. Then I broke my back and it was pretty much forgotten about for 12 months. The end result was total destruction. It looks like the water in the mix evaporated away over the last summer and left a semi dry mud with everything exposed rusted beyond repair.
Obviously, this case is in the extreme, but it would definitely pay to keep an eye on any rust removal projects you have.
Attached File  a1.JPG   446.6K   18 downloads
#13 RallyRed
  • 8,213 posts
Posted 10 July 2020 - 11:29 AM
geez ....that's a mess.
Lucky it was only JP. lol
#14 Shiney005
  • 9,829 posts
Posted 10 July 2020 - 12:27 PM
VT roller cam motor.
#15 Ice
  • 15,221 posts
Posted 10 July 2020 - 05:34 PM
Had my parts in the bath for about 6 months now pretty sure they are still all in there nice and rust free
#16 yel327
  • 13,791 posts
Posted 10 July 2020 - 06:22 PM
At least it was junk and not something valuable!
#17 Shiney005
  • 9,829 posts
Posted 10 July 2020 - 07:23 PM
I used to like you.    :P
#18 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 10 July 2020 - 07:42 PM
Hullo all, from my 40+ years of farming & not in position to use alot of molases, i have witnessed it rust out a couple of 200 litre drums, making quite a mess of the drums. I don’t think I would use it on objects of much value. Jeff
#19 yel327
  • 13,791 posts
Posted 10 July 2020 - 08:00 PM
I meant at least it’s not a valuable engine! They are still easy to find. Unlike stuff 20-30 years older.
#20 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 July 2020 - 10:49 PM
Hi Jeff, I think anything that removes rust if used for too long it'll destroy the good metal. eg sand paper, sand blasting, rust converters, wire brush etc.
Most rust converters eat away, it's all about timing in my book.
Marty
#21 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 11 July 2020 - 09:16 AM
24 hours in citric acid or 7 days in molasses
#22 yel327
  • 13,791 posts
Posted 11 July 2020 - 09:48 AM
What ratio molasses? I have a 307 block and an alloy intake to clean up.
#23 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 11 July 2020 - 09:58 AM
10:1
#24 claysummers
claysummers
  • 3,716 posts
  • Name:Clay
Posted 11 July 2020 - 10:03 AM
Seen a guy do a shell by setting up a sprinkler system using dripper hose and fittings in his shed. Just keeping it wet for a week. Then roll outside and pressure wash. Cleaned off bad surface rust to clean metal. 10:1 molasses.
Messy
#25 Ice
  • 15,221 posts
Posted 11 July 2020 - 10:05 AM
10:1
To weak to get lots of rust off im doing 5:1 ratio
like i said my parts have been in my molasses bath for 6 months and yes some parts came clean after only a weak
but some are taking a little longer not that i check very often
