LJ Heater Box seal
_hommie1973_
Posted 07 April 2016 - 06:06 PM
_NichosJL_
Posted 07 April 2016 - 07:49 PM
cheers in advance
Posted 07 April 2016 - 10:40 PM
There is a rubber seal.
_hommie1973_
Posted 08 April 2016 - 10:00 AM
Posted 08 April 2016 - 10:17 AM
That's what my car has tooThere is a rubber seal.
Edited by lx308, 08 April 2016 - 10:17 AM.
_NichosJL_
Posted 09 April 2016 - 06:29 AM
Posted 09 April 2016 - 08:08 AM
Thankyou S Pack, IThat is what I wanted to know, will go and cut a nice rubber seal and then do a dummy fit up before final fitment. The rubber I am useing is the black 150 mm wide expansion joint rubber used in cementing floors it seems to do the job nicely. Thanks again Hommie 1973
12mm thick may not be enough. To compress the seal you may need it to be around 20mm thick.
That original seal also has the remnants of Holden's grey Flexomastic on it plus it appears it was also contact cemented to the heater box flange flange.
Edited by S pack, 09 April 2016 - 08:10 AM.
_hommie1973_
Posted 09 April 2016 - 10:46 AM
Posted 10 April 2016 - 02:15 PM
I haven't installed it yet, but it looks like either would work.
My original does not look like mastic was used.
Posted 11 April 2016 - 10:02 AM
Just like to know where you bought your seal kit from.
Cheers Graham.
Posted 11 April 2016 - 12:28 PM
Posted 11 April 2016 - 06:37 PM
Doesn't have the round pads for the bolts.
I'll probably use the original seal for the blower outlet as well.
I'm yet to source the internal foam.
eBay, earlybitz2
LJ LC Heater box firewall gasket set
Posted 11 April 2016 - 07:25 PM
Posted 11 April 2016 - 08:28 PM
eBay, earlybitz2
http://www.ebay.com....6EAAOSwNSxVSU~w
That's not where I got mine from. Mine had seals for the bolts, but no rectangle seal. Think the guy's a Kiwi
Posted 11 April 2016 - 09:15 PM
I assume something that will be ok with temperature considering the heater core needs to be wrapped.
