LJ Heater Core
10 replies to this topic
#1 _GP1973_
_GP1973_
Posted 19 May 2016 - 08:42 PM
Hi All.
I have in recent times purchased a March 1973 2 door LJ Torana.
As such I am a new member to the forums and will be requiring guidance and direction in several areas.
Thanks to all in advance !
I have pulled the heater box out as it requires restoration.
First up I got the heater core pressure tested and cleaned up.
The back end reservoir was full of rusty gunk and required to be stripped and cleaned.
Thanks to the boys at ANDRAD Marrickville - top service and quality job.
Can someone advise where the foam/sponge is required ?
Whatever was in there had disintegrated.
I know foam/sponge is required on either side of the flap, however required to the perimeter of the heater core housing ?
Any photos available to assist me ?
Your advice and direction is greatly appreciated.
GP1973
#2 dattoman
  • 16,488 posts
Posted 20 May 2016 - 10:50 AM
A couple of these might help
http://www.gmh-toran...seal/?hl=heater
http://www.gmh-toran...oval/?hl=heater
#3 _GP1973_
_GP1973_
Posted 20 May 2016 - 03:40 PM
thanks dattoman.
Overview shot of heater core helps a great deal.
Looks like not much foam used at all.
GP1973
#4 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 20 May 2016 - 07:46 PM
I picked up some 4.5mm finer filter foam. Look similar to original.
Also found some 3m sealant for the rebuild.
Attached File  image.jpeg   12.28K   3 downloads
Attached File  image.jpeg   14.11K   7 downloads
#5 _GP1973_
_GP1973_
Posted 20 May 2016 - 10:00 PM
Thanks Lc69.
Where did you source the filter foam ?
Sealant applied to perimeter of heater box and sandwich base plate to it ?
#6 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 20 May 2016 - 10:30 PM
Thanks Lc69.
All from evilbay
I haven't built mine yet, but I have some pictures that will help
#7 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 20 May 2016 - 10:33 PM
Attached File  image.jpeg   27.56K   13 downloads
Attached File  image.jpeg   31.17K   15 downloads
#8 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 20 May 2016 - 10:35 PM
Attached File  image.jpeg   45.85K   7 downloads
Attached File  image.jpeg   75.84K   6 downloads
#9 _GP1973_
_GP1973_
Posted 22 May 2016 - 06:11 PM
Bloody awesome Lc69.
The photos will help me out and steer me in the right direction.
Thanks again.
#10 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 22 May 2016 - 08:22 PM
There's a build thread on here, and I have more pictures if needed.
I'm also assembling mine now, so let me know if you need anything.
#11 _GP1973_
_GP1973_
Posted 22 May 2016 - 08:58 PM
Thanks for the build thread advice.
I'm on my way !
Anyone out there knows where I can source the cup head bolts ?
I had to shear one off with the Dremel as nut & thread were rusted shut (I tried over many days to remove - at the end it gave me the shites !).
In metric scale they are 4mm diameter by 70mm long.
If anyone has any I can purchase or steer me in the right direction as I have tried the web and could not find anything.
Thanks in advance.
GP1973
