Hi all...
Well... I have finally got "stage 2" underway on my LC and all is going well... Im just doing some of the final small stuff and plumbing and have some questions for the the guru's about my SU set up... I have triple HS6 1 3/4 and running the blue motor mech fuel pump.
Firstly, did the LC and LJ's run pressure regulators and special fuel pumps?
I got the standard SU conversion kit which looks HOT!!! but... not keen on the fuel distribution block or regulator which was supplied... so, I am making up my own ally 4 way fuel block and fuel lines and thought why do I need to run a fuel regulator on carbies which have needle and seat?
Also, vac advance for the dizzy, my carbs dont have a port for this so where would be a good spot to tap into?
