Edited by sjp67m, 20 June 2016 - 02:02 PM.
Ls1 carb with 4l60e trans controler?
_sjp67m_
Posted 20 June 2016 - 02:02 PM
Posted 29 July 2016 - 08:32 PM
We used an aftermarket controller for a toyota trans behind an LS in a land cruiser.
I cant remember the name was in a blue case, was very capable at doing the job, came with software and manual.
I know it was able to be used on GM.
Worked very well.
Think painless wiring do a witing harness and controller.
We had a local tuner help set it up.
Posted 02 August 2016 - 08:00 PM
Posted 02 August 2016 - 09:17 PM
Just Google some US sites. MSD and B&M have trans controllers. They are cheap enough too to fit under the $1000 GST limit so you can simply get one mailed to you without paying another 10%. Look on Summit.
Also have a look at Wholesale Automatics site, they recommend a brand as well that they sell.
I'm considering putting a 4L60E from a VR-VS behind a SBC in one of my HK's, will be looking for the same sort of thing. Only looking at these rather than LS 4L60/65E as I don't have to buy a special torque converter for it to bolt to a stock SBC. My biggest hassle is getting it to drive a cable speedo, so investigating whether the output shaft from a VN-VP 4L60 can be put into a 4L60E so that a speedo drive gear can be fitted and the extension housing replaced with a VN-VP one so that it has a speedo drive. I know I could just use the 4L60 but I sort of like the idea of having a readily adjustable transmission. You can buy drive units from MSD or B&M to drive your speedo but the cost is as much as the transmission controller.
Posted 03 August 2016 - 08:35 PM
Hi yel327,i have a friend on the sunny coast & we we're talking about auto's 1 day as he is a gearbox & diff specialist & he always converts the 60 to a 65 because it strengthens them heaps. Tci do converters & flywheels to suit 4l60 ect. Can adapt to sbc ect. Check them out they have heaps of stuff
Sorry for the triple post, silly phone !
Posted 04 August 2016 - 12:07 AM
Norton syd a buzz Stav.he specialises in these
trannys.he should definetly know where and
which one to use
Craig 02 97551158
Cheers maz
_LX355SLR_
Posted 08 August 2016 - 07:39 AM
Edited by LX355SLR, 08 August 2016 - 07:40 AM.
