Front flipper window fittings
29 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 25 June 2016 - 07:55 PM
Hi has anyone managed to get the latch fitting off the triangular flipper window ,I have managed to knock the small pin out of the latch ,but how has anyone got the chrome button off?thanks Paul.
#2 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 26 June 2016 - 09:31 AM
Watching with interest. This is on my to-do list as well
#3 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 26 June 2016 - 12:01 PM
Yeah Tony,the back nuts on mine are seized ,I'm going to try soaking them in penetrene for awhile and then hold it with some locking pliers while trying to undo the nut.Dont think there is any other way .With a bit of persuasion I managed to get the pivot fittings off ,they are stuck onto the glass as well as screwed.
#4 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 26 June 2016 - 12:47 PM
Be careful not to stuff the screw heads trying to unscrew them and the latch shaft with the locking pliers .
#5 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 26 June 2016 - 02:33 PM
Ok, thanks. I haven't looked at mine yet, but I need to.
#6 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 26 June 2016 - 05:13 PM
Interested in alternative ideas from members who have done this .cheers .
#7 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 26 June 2016 - 06:46 PM
Mine were pretty badly rusted/seized also. Patience, wd40 & perseverance.
I had to slice a straight slot into one of the screws to remove it & I sourced some better ones to refit.
Good luck
Edited by lx308, 26 June 2016 - 06:47 PM.
#8 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 26 June 2016 - 07:47 PM
I managed to get the pivots off ok with the Phillips head screw heads ,it's just the latch buttons I'm having trouble with ,as you can't really grip them to turn the back nut ,did you re stick the pivots to the glass Tony?
#9 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 26 June 2016 - 08:01 PM
These .
#10 N/A-PWR
  • 9,639 posts
Posted 26 June 2016 - 08:07 PM
Gave you a Like button for that quarter window shot Paul. :)
we never see the nitty gritty shot's like that.
#11 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 26 June 2016 - 08:09 PM
Other side.
#12 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 26 June 2016 - 09:46 PM
Nah. I haven't stuck them back on. I've currently got fibre washers on them but I'm not happy, so they'll go when I find something better. Bunnings has plastic washers but they're too thick.
These .
I think I held the latch side of that with multi grips & kept at it carefully. Can't remember, it was frOcken years ago now...
#13 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 27 June 2016 - 07:10 PM
Funny.
I can remember my old car when these things were always loose.
They were the easiest way to get into the car if you left your keys inside.
#14 N/A-PWR
  • 9,639 posts
Posted 27 June 2016 - 07:22 PM
Ha ha Rob,
I use to lock the Torana up, and get in via the flipper window.
Like button for you. :)
Funny.
loose is right, use your fingernails to rotate the chrome locking knob.
#15 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 27 June 2016 - 08:17 PM
Getting into them was easy.
Stealing the battery was even easier
#16 N/A-PWR
  • 9,639 posts
Posted 27 June 2016 - 08:24 PM
I always took the dizzy rotor button out,
 so the tory was still there when I got back.
I seen the newer locking mechanisms were better designed than the early one's, hey.
#17 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 27 June 2016 - 08:25 PM
Had 3 mates with LCs and LJs before I got my LC
From memory I was the only one not to have the battery stolen.
But I lived in a small town.
#18 N/A-PWR
  • 9,639 posts
Posted 27 June 2016 - 08:30 PM
I had a chain on my battery
screw out gear shifter too
but I had been lucky.
Edit:-
 I see supercheap has chrome inch and a quarter chain on sale for $7 a metre   :)
 look's like this:-
just spotted this:-
cruiser-chrome-chain-i-license-plate-fra
http://www.autobarn....0500series.html
Edited by NA-PWR, 27 June 2016 - 08:44 PM.
#19 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 27 June 2016 - 09:27 PM
Oh man, you guys are killing me, ha ha
The only reason I want to fix my windo is because you can open it from the outside.
I have been scratching my head on security.....sounds like I'm better off buying a big dog
#20 N/A-PWR
  • 9,639 posts
Posted 27 June 2016 - 10:13 PM
I remember how to fix it the dodgy way Tony,
 you put a stub screw in where the locking lever goes over and stops.
drill a small hole and tap it m3 or something, then cut a m3 cheesehead screw down to 4mm long and loctite in.
^ drill the metal sliding tab.
#21 _mikecatts_
_mikecatts_
Posted 28 June 2016 - 06:06 AM
when i pulled apart my quarters.. I killed a few to get what I needed... I used vice grips to grip what I didnt need and saved what I did... I used a dremel to "cut" the bit off i didnt need... I used 8 sets of quarter windows to get 3 sets.. I got the three sets rechromed and sold off the 2 i didnt need and kept 1 for me.. wasnt a cheap exercise to rechrome..... Then Ive got some imperial "red" fibre washers and used them against the glass....
#22 _mikecatts_
_mikecatts_
Posted 28 June 2016 - 06:10 AM
before rechrome
#23 N/A-PWR
  • 9,639 posts
Posted 28 June 2016 - 10:40 AM
Beautiful Job done Mike,
 you sure can show the world how to do things properly. :)
Like buttons for you.
#24 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 28 June 2016 - 12:01 PM
Back in the day there was a little stainless bracket you could buy that fitted over the lever and I think clipped into the bailey channel.
That stopped them from being opened from the outside.
I used to tighten mine up periodically. They loosened off after a while.
Another alternative may be to look at the locking type from a HG or similar and see if it can be used.
#25 Indy Orange
Indy Orange
  • 2,968 posts
  • Name:Paul
Posted 28 June 2016 - 05:50 PM
Great job Mike as always ,well I've managed to completely bugger up one so far trying to unscrew that back nut but I still have two more I can try ,I have them soaking in diesel.
Edited by Indy Orange, 28 June 2016 - 05:50 PM.
