But it will depend entirely on the engineer and what weight he or she will accept as the "heaviest sedan variant" (note that they use the sedan weight whether it be a sedan or hatch).
If you refer to Dr Terry's book "60 Years of Holden", the weight of the heaviest sedan (being the A9X) is 1306kg, so 5x that gives a maximum capacity of 6530cc, meaning an LS3 should pass no problem.
However, I've seen a list from the NSW LVCOP which only has an SL/R5000 listed as the heaviest variant at 1205kg, so if you 5x that it's only 6025cc capacity, meaning an LS2/L76/L77/L98 is okay but an LS3 is not.
And then there are examples on this forum of engineers approving a supercharged LSA in a Torana which is WAY outside the guidelines!
So the bottom line is, don't take anything for granted unless it comes direct from an engineer's mouth (and even then you should get it in writing) and remember you can shop around and interview a few different engineers, you will probably find each has a different interpretation of the "guidelines".
