Cleaning fouled plugs
14 replies to this topic
#1 rexy
rexy
  • 3,761 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 09 July 2016 - 08:21 PM
Any tips?
I have tried brushing the tips clean and running sandpaper through the gap to give clean metal. The plugs never seem to behave particularly well despite best efforts.
Am I wasting my time? Are they stuffed once blackened?
#2 _dno_
_dno_
Posted 09 July 2016 - 08:34 PM
Ive found the same with bike plugs, seems our quality modern fuels stuff them once there fouled.
#3 N/A-PWR
  • 9,639 posts
Posted 09 July 2016 - 08:40 PM
Hello Rexy,
 My friend used a normal air gun small tip type sandblaster,
 and he just held the spark plug in his left hand with the spark plug electrode facing upwards to the side,
 and just simply wiggled his low pressure sandblaster in the right hand at the end of the spark plug.
Then he simply rotated the spark plug as he blasted, and puff's air in to aid as you go. :)
End result was a nice clean plug with no damage. :)
Edit:-
 I must say that he just did it in front of me in the workshop, no booth or anything like that,
 as you can imagine not much media would come out to clean a plug.
I would say the plug was clean in 4 seconds flat.  :clap:
If anything, it would be a sweep up on the floor of minimal debris.  :spoton:
Edited by NA-PWR, 09 July 2016 - 08:53 PM.
#4 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 09 July 2016 - 09:23 PM
had the same thing happen with my two stroke bike when it was fouling plugs , the only thing that would get them working was to clean down the side of the insulator
#5 _Mint_
_Mint_
Posted 09 July 2016 - 09:34 PM
might want to find out why the plugs are fouling in the first place...too much fuel...not enough timing..i have seen a DIY soda blast kit work quite well but the problem is you cant get ALL of the plug clean specially down the bottom of the insulator
#6 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 09 July 2016 - 11:20 PM
Its not about the electrode being clean, its about the insulator being clean, the black deposit is carbon, carbon is conductive and shorts out the plug so it can not fire. As long as the insulator is clean the plug will fire.
Best way to clean is bead blast, as mentioned previously, you can blast down inside quite well, but its not that important, as once its firing, it should self clean once running and gotten to full operating temp.
Another reason for fouled plugs is too cold of heat range, the plug never gets hot enough to burn off the contaminants on the insulator, then..... fouled plug. The conventional wisdom is a hottie engine needs a cold plug, but really, unless detonation or some such thing is a problem that is being tuned for, you really should run as hot a heat range as is needed to keep the plugs clean.
#7 Ice
  • 15,213 posts
Posted 10 July 2016 - 02:51 AM
Buy some NGKs
#8 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 10 July 2016 - 07:59 AM
I'd be hesitant about using media blasted plugs myself. If there's any of the abrasive media not cleaned out that could come out later I assume that it could damage the bore.
If the plugs are that bad just fit new ones and tune the engine to stop the problem reoccurring.
If you're in need of cleaning them to make do until you replace them you can use carby cleaner, a brush and compressed air.
#9 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 10 July 2016 - 09:04 AM
Bead blasting plugs was standard practice years ago, and still is in the aviation industry, plugs used to be and still are serviced, blasted, inspected, gaped and then their ability to still produce a spark while under simulated cylinder pressure (compressed air).
Like with anything, do it properly and its fine, I've blasted literally hundreds of plugs and never any trouble.
It could be an almost new plug that's been fouled but an unlucky cold start, too much fuel, maybe the crab is a bit fat and it got a bit too wet and suddenly a fouled new plug, no way known i'd be putting it in the bin if it as new and only needed a clean, gone are the days of buying an NGK for less than $2. Actually, I'd still blast it if it was only $1, quicker than going and getting another one.
#10 _big jack_
_big jack_
Posted 10 July 2016 - 09:26 AM
You need one of these,every mechanics workshop had one.
They come up for sale on ebay from time to time.
Or you could try these.
http://www.ebay.com/...rk-plug-cleaner
#11 _oldjohnno_
_oldjohnno_
Posted 10 July 2016 - 09:40 AM
A decent tune, decent ignition and an appropriate heat range simply won't foul plugs. It probably makes more sense to fix these things than to mess around with black plugs.
#12 _dno_
_dno_
Posted 10 July 2016 - 12:22 PM
I totally agree with fixing/finding the cause, my problem was an intermittent electrical fault above 5000rpm.
#13 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 11 July 2016 - 12:49 AM
Abrasive paper leaves a residue on the plugs, I wouldn't say you are wasting your time but as said getting to the root of the problem would be a good thing. I've always used a small file and then a cleanup with lacquer thinners, seems to fix the problem. I went up a heat range in my car and seemed to resolve my fouled plug problem.
Cheers Dave
#14 _oldjohnno_
_oldjohnno_
Posted 11 July 2016 - 09:52 PM
The little sixes seem to like warmish plugs, as a very rough guide you could use the following (numbers are NGK, can't think why anyone would use anything else):
5 - Good for granny who just potters around town and never drives at full throttle
6 - Daily driver street car that never sees much more than a few seconds of full throttle at a time (and that's most street cars)
7 - hotter engines that see some full throttle work, or stock/mild engines that get extended full load work like heavy towing
8 - high output n/a engines that see extended WOT
9 - very high output, continuous WOT
Generally, for a street car, I like to use the hottest plug that won't preignite, usually a 6 or 7. But it depends on how you drive and you can't expect to be able to use the same heatrange on both the street and the track.
#15 _Agent 34_
_Agent 34_
Posted 12 July 2016 - 05:24 PM
three cents;
we and still do get a hacksaw blade and shape it on the bench grinder " in from both sides " and then use this to access the bottom of the plug where the insulator is . works a tread.
sandpaper gap
reset and clean with solvent.
one of the earliest memories of my dads shed and fiddling with motors and stuff that wont go - " clean the plug first and check for spark "
but fix problem first as the above gents said.
