Koni shocks with lowered King springs
12 replies to this topic
#1 _Ls1_sshatch_
_Ls1_sshatch_
Posted 16 July 2016 - 03:24 PM
Hey guys, my new 9 inch arrived yesterday so I'm trying to get everything together to fit it. I've got a new set of 30mm lowered King springs which have been sitting in the shed for over 10 years now which I intend on using with a set of koni adjustables.
Now I've heard a few people have had problems with springs falling out when fitting the koni shocks with lowered springs. Will 30mm lowered be alright or should I be looking for a different shock? Just wanna make sure before I fork out the $$$$.
And a little off topic but I've seen there has been quite a bit of discussion in the past about adjustable trailing arms. I've been looking into these for a while now and havnt been impressed mainly by the look of the McDonald bros and whiteline arms. Personally I don't think the whiteline ones look strong enough either. I've just ordered a set from the states built for our toranas. Cost $780 Australian dollars inc freight, for adjustable upper and lower arms, so there on par with our local ones but the presentation and build quality looks great. Google (pmt torana adjustable trailing arms). To check them out. I'll do a review on them after I recieve and fit them up
#2 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 16 July 2016 - 07:19 PM
Mine's got Koni's and lowered Lovels in the rear, but that was a million years ago I bought all of that.
BUT, I do remember being able to buy the Koni's shorter than standard length at the time, for that exact reason, and I'm kind of sure that's what I got supplied buy the place I got it all from.
May need to ask, as all of my stuff was about 25 years ago.
#3 _Ls1_sshatch_
_Ls1_sshatch_
Posted 16 July 2016 - 08:14 PM
The only ones I can seem to find are the 802299 which are the ones I've heard the bad stories about. I'll keep searching though
#4 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 17 July 2016 - 08:28 AM
I've spoken with the guys at Fulcrum in Brisbane a few times and they were very helpful. My rear's have had the valving rates changed to help stop axle tramp, they did this work and seemed like they knew what was what, well it all worked when it came back.
Its from a while ago, but the number I have is 07 38929000.
#5 LXTASY
LXTASY
  • 9 posts
  • Name:Paul
  • Car:LX Torana Hatchback
Posted 17 July 2016 - 08:59 AM
I have koni pt# 80-2233 (suit commodore wagon, VL etc) for the rear of my LX.
They aren't fitted as yet, but were suggested as an appropriate length shock for lowered LX's.
I think the crush tube just needs to be removed from the shock mount to 'drop straight in'.
Maybe do a forum search with a few of those key words and read up if suitable for your application?
#6 _Ls1_sshatch_
_Ls1_sshatch_
Posted 17 July 2016 - 11:06 AM
I've checked these ones out and they are to suit 50-60mm lowered rear so probably not suitable for my 30mm drop. I might give fulcrum a call. How much did they set you back with the valving done mick?
#7 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 17 July 2016 - 09:09 PM
Its a bit hard to remember, was maybe 8 years ago, but I kind of remember somewhere around $120, but the rears had to be looked at anyways, as one had started to weep with signs of dust sticking to the outside, so the valving rates were done at the same time.
The car used to either blow the tyres off or if it tried to get traction it would axle tramp something crazy. The broken crap I've replaced over the years from axle tramp is plenty long enough for a afternoon of reminiscing in the shed.
The redone shocks are FIRM!!! maybe beyond what some would call acceptable, but I find them ok as I like a firm ride, their minimum setting is probably firmer than the max setting available on a standard shock, but they stopped the tramping all together.
#8 _Ls1_sshatch_
_Ls1_sshatch_
Posted 17 July 2016 - 10:51 PM
Sounds like you've got yourself quite a weapon. Thanks for your help mate. Gonna order the 802299 shocks and see what there like, I can always send them away to be shortened and revalved if need be. Cheers
#9 ozyozyozy
ozyozyozy
  • 953 posts
Posted 19 July 2016 - 06:38 PM
Bilsteins are the best off the shelf shock for them.
They are a monotube shock, have a larger piston to help control damping better, more sensitive, requires less effort.
Koni are twin tube, smaller piston, they have a harder time to control movement, its almost impossible to find a true happy medium between high shaft speed and low shaft speed damping
#10 _sbc57lx_
_sbc57lx_
Posted 20 July 2016 - 09:00 AM
May be check the length of HT   &  HQ shocks,    I think the HT shocks are 35mm shorter & the HQ shocks are 25mm shorter then LX shocks,
 a shock retailer should be able to check fitment.
#11 Heath
Posted 20 July 2016 - 05:09 PM
Excuse my ignorance, but does a shock absorber care what range of its stroke you are using (both position and length of stroke)?
Short of repeatedly trying to over-extend or over-compress it...
#12 ozyozyozy
ozyozyozy
  • 953 posts
Posted 20 July 2016 - 07:10 PM
Yes some shocks to get affected if the piston is not in correct position at say ride ride height.
#13 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 28 September 2016 - 09:29 PM
We have found the konis to low springs drop out, but place here in melb 80 dollars to shorten them! Problem solved
for me it was having to remove the tail pipes every time it went on the hoist as they go under the diff!
