Quadrajet what goes where?
9 replies to this topic
#1 _abstar_
_abstar_
Posted 04 August 2016 - 11:36 AM
Ok next job, fitting this quadrajet  to a 77 LX can anyone tell me what goes where? I have some exploded diagrams but they really arent clear
Attached File  Carby Front 17057294.png   786.27K   15 downloads
Having trouble putting up the rear photo but also 2 ports at the back
Thoughts?
And Rear
Attached File  Carby Back.png   677.71K   9 downloads
#2 hanra
  • 11,025 posts
Posted 04 August 2016 - 11:51 AM
LH may or may not be similar?
#3 yel327
  • 13,768 posts
Posted 04 August 2016 - 12:17 PM
Auto or manual?
#4 _abstar_
_abstar_
Posted 04 August 2016 - 02:13 PM
auto
#5 yel327
  • 13,768 posts
Posted 04 August 2016 - 02:31 PM
Rear 1 is dizzy for an auto, blanked on a manual.
2 is PCV as you have.
4 should be the purge on the canister (ported vacuum) - used also with a T-piece for dizzy vacuum advance on a manual.
1 or rear 2 is for the aircleaner heat flap. I'll figure out what the other one is later. The carb is actually too late for an LX unless it is most A9X, it is actually a HZ carby. The right carby is a 17056280 (the first few A9X's had this carby too) . Won't make much difference though.
#6 _abstar_
_abstar_
Posted 04 August 2016 - 03:33 PM
Thanks for the info yel327
Heads im throwing on are ported so didnt want to strangle them running the original 2 barrel and manifold hence the change to 4, hopefully put a bit of kick into the 253
Car is 12/77 so pretty late but not A9X unfortunately  :D
#7 yel327
  • 13,768 posts
Posted 04 August 2016 - 06:00 PM
It is the right carby then assuming for a moment that GMH would have fitted one to a red 4.2L.
Just checked the HZ diagram (see attached) and referring to your numbers on the picture:
1 goes to the front port on the RH side plastic Xmas tree on the inlet manifold (rear port to the EGR valve) (applicable to auto only as manual don't have an EGR valve). Torana may be the opposite on the Xmas tree.
2 is PCV.
3 is canister purge.
4 goes to the rear port on the TCS solenoid (side port of TCS goes to the dizzy via a delay valve, front port goes to the front port of the passenger side plastic Xmas tree. Middle port of Xmas tree plugged. Rear port to intake manifold).
Rear 1 is the pipe that goes to the air cleaner switch up near the carb opening.
Rear 2 I don't know. I don't recall seeing that on a HZ carby before.
Edited by yel327, 04 August 2016 - 06:01 PM.
#8 Dr Terry
Dr Terry
  • 3,341 posts
Posted 04 August 2016 - 06:24 PM
Rear 2 is the fresh air supply to the auto choke heater.
Dr Terry
#9 yel327
  • 13,768 posts
Posted 04 August 2016 - 07:57 PM
^^Voila Dr Terry! I had it stuck in my head that the choke air supply came from the air cleaner but that was the HQ-HJ engines that did that.
#10 GMHAz
GMHAz
    Driving the Dream
  • 1,175 posts
  • Name:Aaron
  • Car:1977 Hatchback
Posted 04 August 2016 - 08:08 PM
I'll be doing the same swap & as always great info as usual guys...... A wealth of knowledge
Cheers Aaron
