decoding 253 engine prefix
13 replies to this topic
#1 _hatchy1_
_hatchy1_
Posted 12 August 2016 - 05:05 PM
hi guys hoping someone on forum can help out with decoding my 253 from my ss hatchback on rego papers it states HR56376 but on a letter from holden i recently received it states R056376 im confused as to what the letters actually mean on both the holden letter of authenticity & rego papers as the numbers are the same cheers
#2 _Skapinad_
_Skapinad_
Posted 12 August 2016 - 05:11 PM
0 there because not 6 numbers yet ?
I have no idea, but did see a nos block on Facebook the other day... I would have thought a replacement would be an NR ? This one was NSR ?
#3 S pack
  • 15,745 posts
Posted 12 August 2016 - 06:09 PM
Correct Adam.
The Holden mainframe required six digits be entered in the data field so if the engine number was only 5 digits long it would have a 0 inserted to complete the data field.
Hence the number stamped on the engine is HR56376 but GMH records show it as R056376.
Edited by S pack, 12 August 2016 - 06:09 PM.
#4 _hatchy1_
_hatchy1_
Posted 12 August 2016 - 07:43 PM
much appreciated fellers thanks for your time and knowledge  :driving:
#5 _Skapinad_
_Skapinad_
Posted 12 August 2016 - 07:50 PM
Ang ideas on the NSR Dave ?
#6 S pack
  • 15,745 posts
Posted 12 August 2016 - 07:56 PM
I think you will find it is N5R not NSR.
N5R is the prefix for the GMP&A replacement 4.2 litre Blue motor block & piston kit and short motor.
#7 S pack
  • 15,745 posts
Posted 12 August 2016 - 11:02 PM
Your LH Torana 253 engine is the 56,376th engine in the H number series. Your engine number tells us that and so does the engine number listed on your letter from GMH.
In reality though it is actually the 55,376th engine as the number series starts at 1,001.
#8 _Skapinad_
_Skapinad_
Posted 12 August 2016 - 11:14 PM
Yep, was a 5. Saved pics at work. Only remember as all the 5's had the banana bend on top.
#9 _hatchy1_
_hatchy1_
Posted 12 August 2016 - 11:45 PM
s pak its actually an LX  not LH 253
Also does anyone know what the letter and chassis numbers actually mean as in ALX 001075M CHEERS
#10 S pack
  • 15,745 posts
Posted 13 August 2016 - 12:27 AM
LH/LX doesn't matter really they both use the same Torana H series engine number prefix except for ADR 27A automatic cars which use the HQ series Q prefix engine numbers for the 173 and 202.
LX is obvious.
The A is the first ADR year for the LX chassis. The chassis prefix should have changed to B ie BLX when next any ADR rules changed or were added.
001075 = 1,075th LX Chassis and the M= Melbourne (Dandenong Vehicle Assembly Plant)
#11 S pack
  • 15,745 posts
Posted 13 August 2016 - 07:08 AM
Forgot to mention that the Torana Opel 1900 engines have their own engine number sequence. The H series engine prefix is 6 & 8 cyl engines only.
#12 yel327
  • 13,724 posts
Posted 14 August 2016 - 12:57 AM
Dave, most LH auto 6cyl and pre ADR27A 6cyl auto LX use Holden engines too. No X on these either.
#13 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 15 August 2016 - 09:31 AM
Also HR is a 253 prefix denoting LH Torana / LX Torana High Compression
HS is a 253 prefix denoting LH Torana / LX Torana Low Compression
s
Edited by StephenSLR, 15 August 2016 - 09:32 AM.
#14 _Skapinad_
_Skapinad_
Posted 15 August 2016 - 10:58 AM
Attached File  13901571_1084512654930643_4367629621783130919_n.jpg   43.39K   1 downloads
