chemi weld - on engine bay - how to get off - it's left white marks -FAAARK
11 replies to this topic
#1 _Agent 34_
_Agent 34_
Posted 14 August 2016 - 05:54 PM
Put some product similar to chemi weld in the GTR - the thermostat coughed open, blew pressure into the radiator - the recoverable cap let the fluid into the storage tank - then it spashed all over the engine bay.
it was a little bottle with what looked like a clear liquid and then what looked like a rust emlusion at the bottom - you shake the bottle and pour into the radiator - but it's not chemi weld - I just cannot remember the name.
It's ;left what looks like a white scale or calcification that has attached itself to everthing and anything under the bonnet and engine bay - to which I'm massively Pissssed to say the least.
tried mineral turps - wax and grease remover
any suggestions on cleaning will be appreciated
g
#2 _Agent 34_
_Agent 34_
Posted 14 August 2016 - 06:19 PM
this is the product
http://www.superchea...eak-250mL/0468
#3 Indy Orange
Indy Orange
  • 2,967 posts
  • Name:Paul
Posted 14 August 2016 - 06:27 PM
Would a light cut and polish get it off?
#4 kiwi-lilj
kiwi-lilj
  • 1,428 posts
  • Name:Blair
  • Car:LIL J
Posted 14 August 2016 - 06:28 PM
Sandblaster?
#5 _Agent 34_
_Agent 34_
Posted 14 August 2016 - 06:49 PM
found the techinical data sheet - it's a sodium silicate.http://www.afcintern...Tite [TECH].pdf
gesus not the sandblaster
 may give the cut with some compound . but that's going to be hard work around the lower chassis and rat trap
I will ring them up tomorrow as this matter will not be new - hopefully there is a chemical or a supplication which will neutralize the oxidation - if not I'll be devoed .
g
Edited by Agent 34, 14 August 2016 - 06:50 PM.
#6 S pack
  • 15,740 posts
Posted 14 August 2016 - 07:10 PM
Some info about Sodium Silicates. Seems like it will be tough getting this stuff off your paint etc.
http://www.pqcorp.co...letin_12-31.pdf
#7 Indy Orange
Indy Orange
  • 2,967 posts
  • Name:Paul
Posted 14 August 2016 - 07:33 PM
Try Nu Finish polish ,it's got a very slight abrasive in it ,it may help.
#8 piquet
piquet
  • 857 posts
Posted 14 August 2016 - 07:42 PM
you could also try some Xylene.  Also known as the thinners for slate sealer. Nasty stuff but it moves just about anything. wear gloves and do it outside in fresh air.
#9 _Agent 34_
_Agent 34_
Posted 14 August 2016 - 08:00 PM
pretty sure the engine bay is two pac.
then engine isnt .
thanks but after a bit of reading it look stubbon.
g
PS it came of the paint work - but the black of the engine bay is another story.
Edited by Agent 34, 14 August 2016 - 08:01 PM.
#10 S pack
  • 15,740 posts
Posted 14 August 2016 - 08:03 PM
Thank Christ for that Grant.
#11 _Agent 34_
_Agent 34_
Posted 15 August 2016 - 07:17 PM
Bit of an update, i rang a bloke who i know is a retired chemical engineer and he has said that a few things will remove it;
EDTA
chelin
A mixture of one of these with a soap product and BLOODY boiling  HOT water.
I have a test patch this morning and it's looking it can get it off albiet very slowly and a really good scrub.
so it's looking better than it did yesterday.
I know all about the product now and why it's used.
G
Ps no sandblaster needed
#12 RallyRed
  • 8,179 posts
Posted 15 August 2016 - 07:38 PM
you better buy some boxing gloves Grant...you are fighting two cars at once!!
