460LE trans in LC?
Posted 19 August 2016 - 07:41 AM
Will the 460LE trans fit in a LC with out major tunnel mods? I believe this is the one with a cable control not ecm controlled but could be wrong. Had one in the 57 and seemed to handle the big block but never really gave it a hard time.
And does anyone know what the size difference is between it and a trimatic? Car currently has a traumatic with plenty of room to spare.
Posted 19 August 2016 - 08:46 AM
Posted 19 August 2016 - 10:24 AM
ummm. I got nothing other then frOck up kentWhat happened to nah im not gunna frOck with this one pppfffttt BS you just kent help ya self
Posted 19 August 2016 - 11:24 AM
what is a 460LE ? do you mean a 4L60 or a 4L60E ?
Edited by UCSLE, 19 August 2016 - 11:25 AM.
Posted 19 August 2016 - 11:43 AM
Typo. Yes 4L60-Ewhat is a 460LE ? do you mean a 4L60 or a 4L60E ?
Posted 19 August 2016 - 11:49 AM
Posted 19 August 2016 - 11:50 AM
can't comment on the way it fits but with the 4L60-E the E stands for electronic and it needs a ecm .
4L60 is the cable controlled version
Posted 19 August 2016 - 01:06 PM
No thanks Blair. Are Torque powers any good behind a 308?
_Skapinad_
Posted 19 August 2016 - 02:20 PM
Posted 19 August 2016 - 03:52 PM
Thanks Troy. That makes senseNo thanks Blair. Are Torque powers any good behind a 308?
lol
No but they are great behind those 1900 things
Posted 19 August 2016 - 05:38 PM
Pretty much like trying to fit in th400...make trimatics look tiny.
Have to chop bits off bellhousing & trim/grind excess basically to match block it bolts up to for exhaust clearance.
Then slice big chunk off other side to get as much steering clearance.
After having trimatic behind 355ci 4500 stally 4.5 geared vh sle all you really need is good auto builder.
If it's overdrive you want sounds like a lot of work especially if it's early block aussie bolt pattern...5spd supra or t5 seems easier
Posted 19 August 2016 - 10:17 PM
Was thinking of gear vebdors overdrive behind a th350 but thought this may have been a cheaper option
Posted 20 August 2016 - 12:10 AM
If current block was turbo pattern it would be.
I've used a dellows adaptor kit before...it's ok just not preferred way to do it.
Once you've done all the little mods required it would be set & forget....they're absolute mongrels with v8's to work on usually means engine in/out a few times to get right.
However if got a hoist & can do the roll front end under-lower car down then would be do-able without going insane lol.
These are light as I'd try taller gearing first then a th700 conversion next...it's bit bigger than th350.
Dont forget aussie bolt pattern issue to deal with.
Posted 20 August 2016 - 08:03 AM
Starting to get the shits with the idea already lol
Posted 20 August 2016 - 08:36 PM
You mentioned a Gear Venders, I have wondered if they do one, or could do one for a TH180-Trimatic, or if the one for a power glide might be close enough with some mods.
Posted 20 August 2016 - 08:45 PM
Not sure Mick. They do them for a fair variety so the might?
Edited by IMORAL, 20 August 2016 - 08:45 PM.
_LS2 Hatch_
Posted 22 August 2016 - 10:41 PM
The box fits in an LX with a slight massage with a hammer, maybe it will still fit the smaller Torana?
Food for thought
Posted 22 August 2016 - 10:45 PM
First major thing is yours is trimatic pattern it will need adaptor kit or block redrilled as th700 is turbo bolt pattern.
Next is bellhousing clearance particularly steering section...few hours on grinder.
Then few more making sure extractors fit in..have had to remake hurricane brand to fit with early heads...also remake bottoms on steel hsv/calais headers with efi heads.
Trimatic or p/glide look very roomy compared to turbo box
Most turbo pattern auto need 2 knuckle mod whereas some trimatic/m21 cars just get away with 1 knuckle.
It's doable once you spend time setting it all up but first you got bolt pattern issue to solve.
As an aside I've bolted up trimatic/banjo tailshaft to get cars driving.Each car different when messing with old holdens.
Lh/x torries & early commodores seem huge when you can fit ya hands in them not get stuck lol
Edited by gtrboyy, 22 August 2016 - 10:51 PM.
Posted 22 August 2016 - 10:57 PM
#21
Posted 01 October 2016 - 02:29 AM
The 4L60-e is an electronic box.
You'll find they're getting pretty expensive nowadays. As not many good ones left.
The trans case normally shits itself.
What about a later 5L VT commo box?
Pretty sure they have a removable bell housing from memory?
Just get the bellhousing modified to suit trimatic pattern or check with dellow, crs etc. And go full manual shift, or by the stand alone trans ecu
Think b&m and msd etc do them?
#22
Posted 01 October 2016 - 07:53 PM
