TA Torana conversion
TA to LC - LJ conversion
14 replies to this topic
#1 _McClutha_
_McClutha_
Posted 19 August 2016 - 10:09 PM
Hello all..
I have the opportunity to pic up a very cheap TA Torana... but it really isn't what I am after (currently have a 2dr HQ which is a bit more my thing) but the TA is the right price.
I understand that it would be a big job, but what would be involved to convert the TA Torana to a LC-LJ front end (Firewall forward)?
I may have a donor 4dr LJ lined up that could be used to swipe parts from..
Any links or suggestions would be helpful..
Thanks,
Chris
#2 Dr Terry
Dr Terry
  • 3,328 posts
Posted 20 August 2016 - 07:35 AM
I assume that you want to fit the longer 6-cyl LC/LJ front, not the 4-cyl LC/LJ, which are the same as the TA.
It's a huge job, because the firewall very different also.
IMHO it would be better to do a cut & shut thru the A-pillar & the floor under the driver's seat.
There are also minor differences in the rear suspension mount points.
Big job either way.
Dr Terry
#3 Redzone
Redzone
  • 517 posts
  • Car:Mini torana's - Gemini coupe 10.787@123mph, log booked Group A DOHC Gemini under resto..
Posted 20 August 2016 - 09:42 AM
Probably easier to swap the side panels from the 2 door TA to the 4 door LJ.
#4 _Lazarus_
_Lazarus_
Posted 20 August 2016 - 09:53 AM
You could leave it as is and stick a good four in it. Something like a 4AGE with a 20 valve head, 5 speed and a G142 diff from a RN20 Hilux.
http://www.billzilla.org/4agstock.htm
#5 Potta
Posted 20 August 2016 - 01:35 PM
Yeah fix up the 4 door with bits from the TA.
If you want a 2 door you can unpick the side panels and swap them, and move the B pillar.
Easier with a better end result.
TA's are the UC of the LC/LJ family, you know what I'm saying
#6 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 20 August 2016 - 01:51 PM
They're awesome? :stirpot:
#7 Potta
Posted 20 August 2016 - 03:03 PM
Yes, exactly what I meant
#8 S pack
  • 15,740 posts
Posted 20 August 2016 - 06:31 PM
I don't believe the OP stated if the TA is 2dr or 4dr. He did mention though that he has a 2dr HQ Holden.
#9 _Lazarus_
_Lazarus_
Posted 20 August 2016 - 07:11 PM
The 2dr doesn't look too bad from this angle -
https://www.bing.com...b25ade3730335o0
#10 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 20 August 2016 - 09:10 PM
I like grandpa toranas but TA s a grandma torana
Perhaps you could leave as is and drive to crochet lessons or to the chemist to buy some adult nappies
#11 Dr Terry
Dr Terry
  • 3,328 posts
Posted 21 August 2016 - 10:03 PM
What would be the point of grafting an LC/LJ front from a 4-door LJ (donor) to a 4-door TA ? You end up with the same thing !!
Dr ETerry
#12 Ice
  • 15,212 posts
Posted 21 August 2016 - 11:07 PM
Hello all..
Thanks,
Chris
Honestly your money but imho i wouldnt bother all that work and it might be worth a couple of grand tops
think long and hard about why you want to do this
#13 S pack
  • 15,740 posts
Posted 21 August 2016 - 11:20 PM
Dr ETerry
I agree Dr T, however, I was just stating an observation in relation to the OP's post.
#14 _Hot Rods_
_Hot Rods_
Posted 31 August 2016 - 09:41 AM
Hi everyone
I have a TA 2 door, which I was going to use as a donor
It doesn't have any front, or rear suspension.
I might change my mine about it being a donor, and put a 4 turbo in it.
I was wondering if any one has bolted a different front, and rear end into a TA???
Example: would a Sigma, or Silva bolt in (would give me 4 wheel disc brakes etc).
I was going to put a 6 nose cone on it, and cut down a 6 bonnet to suit.
Pete
#15 _McClutha_
_McClutha_
Posted 31 August 2016 - 09:02 PM
Thanks all for your input..
It was a 2dr TA.. And after crawling in, on, over and under the TA... I've decided to give it a miss..
Would be a huge job.
Thanks again.. :-)
