Tacho reading 2000rpm too high?
12 replies to this topic
#1 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 25 August 2016 - 11:50 PM
Im sure its been discussed numerous times but I cant find the answer.
Problem: Lc with 202. Crane cam fireball hi-6 ignition system
Connect the tach output wire to tach. Nothing
Connect a wire from -ve side of coil. Tach reads 2600rpm at idle. Same reading with 3 gtr dashes. Tried a cheapo after market one. Same thing 2600
Tried auto meter one while still on -ve side of coil. Nothing.
Connected it to tach out put. 650 rpm.
I tried 4 different resistors but they made no difference
So my question is how are you guys getting your geniune tacho working when using electronic systems?
TIA
#2 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 26 August 2016 - 03:54 AM
Hi Paul.sorry i cant really help you but
when i got my wiring converted to run gtr
dash Aaron (sparky) asked if i was going to
use electronic dissy ,i said.. yeah later..so
he just mentioned the resistance wire for
points only gives out 8 volts and just
wired in another pink wire for when i go electronic.thinking maybe you will have to
do the same..
Edited by madtoranajzedded, 26 August 2016 - 03:54 AM.
#3 _COSH_
_COSH_
Posted 26 August 2016 - 07:08 AM
TIA
You need a Tach Adapter.  Just make sure you pick the correct one for your ignition type: Points or electronic.
8910 is for points, 8920 is for electronic.
#4 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
Posted 26 August 2016 - 07:52 AM
do the same..
That will be so you have 12 volts instead of 8 for the unit
I will look into it thanks
#5 S pack
  • 15,728 posts
Posted 26 August 2016 - 07:54 AM
Installation Instructions. Maybe someone else can work out how to fix.
https://static.summi...n-6000-6440.pdf
#6 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
Posted 26 August 2016 - 11:30 AM
I brought a MSD tach adapter today so when it arrives next week I will see if it fixes it
#7 LJ RB30
LJ RB30
  • 1,039 posts
  • Name:Trevor
Posted 26 August 2016 - 12:43 PM
Yep I used the msd tach adaptor on my crane hi6 to run the stock gtr tacho.
The msd ones look nicer than the crane ones too!
#8 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 26 August 2016 - 01:48 PM
Oh.ok..so i will have to get an adapter
aswell bud, when i change to ice ignition
or is this just for the fireball hi 6
Edited by madtoranajzedded, 26 August 2016 - 01:50 PM.
#9 LJ RB30
LJ RB30
  • 1,039 posts
  • Name:Trevor
Posted 26 August 2016 - 04:32 PM
I have no experience with ice ignitions but at least they are local to be able to ask them if you have issues.
MSD's & Cranes only really need them with certain types of tacho's ie old Holdens!
Edited by LJ RB30, 26 August 2016 - 04:35 PM.
#10 jd lj
jd lj
  • 2,117 posts
  • Name:James D
  • Car:LJ
Posted 26 August 2016 - 06:48 PM
The factory tachometers read a coarse signal but the msd 6-al2 gives off a fine signal. The local instrument repair guy in my area did something to modify my tacho and it now works fine (with no tach adapter). I just took the instrument panel to him and he worked his magic.
#11 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
Posted 26 August 2016 - 09:15 PM
Bloody beauty. Good to know
#12 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
Posted 07 September 2016 - 09:51 PM
FYI
The msd tach adapter has it working like a new one. Happy days :spoton:
#13 LJ RB30
LJ RB30
  • 1,039 posts
  • Name:Trevor
Posted 07 September 2016 - 10:52 PM
:spoton:
