Mine is also a 5lt, I purchased a book published by Gregory's from Repco some time ago for around $45.00. The book I have from memory is version 3 which includes many other manufactures plus V6 & V8 Holden engines up to VS They contain wiring diagrams and information on repairs relating to all the fault codes for that particular engine. Very good diagrams and easy to understand text and repair procedures. I think Gregory's version 4 has the VT 5lt included in it. These books only relate to E.F.I component and electrical and don't touch on rebuilding the engine, just what you need to check through to insure all the hook up are correct and the wire identification.
I connected the original VS wiring harness to a VZ fuse box due to being compact with mini fuses and relays. And a point to connect the LH wiring into which is only a few wires. My coil, map sensor and some other electrics are behind the redundant heater blower and ECM inside below the A/C evaporator. The only difference between VS & VT is the sequential injection wiring and some distributor changes.
Lenny.
Edited by axistr, 02 September 2016 - 02:01 PM.
