LS and 6L80E
14 replies to this topic
#1 _LX355SLR_
_LX355SLR_
Posted 08 October 2016 - 11:43 AM
Hi Guys,
Ive been having dirty thoughts about putting an LS into my sedan. looking for a very well mannered motor that had shit loads of torque and came across an LSA which is great value.
Can these be engineered or just the ls3 N/A.
Can you fit a 6l80e in the tunnel or will it require cutting. I have a 4l60e and its apparently rated to 800hp but wouldnt like to find out the hard way. Also i believe the bellhousing and convertor and different bolts patterns.
I spoke to one tranny builder who said the 4l80e should fit if i got the turbo 400 in there before but it might be cheaper and easier to get the 6 speed and would be a lot smoother on the road.
let me know your thoughts.
#2 dattoman
Posted 08 October 2016 - 05:07 PM
I'd bet Skaps hairy nuts the 6L80 will need floor mods
#3 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 08 October 2016 - 05:22 PM
i am in the middle of a LS plus 6 speed conversion in a LH
My advice would be dont do it ....but i did ...lol ....and let me tell you every thing needs to be modified which all cost big $$$
Yes things can be made to fit and I made things worse for myself as went over the top with big brakes big wheels and tubbing the rear end and full chassis right through the whole car
if I had my time again I would go a strong 355 motor
Cheers Kevin
#4 _LX355SLR_
_LX355SLR_
Posted 08 October 2016 - 06:29 PM
did you cut the floor for the box big kev? and was it an A6 or stick shift. My 355 would be limited to 430is rwhp where the lsa would start there and be better on fuel and more reliable hat whats giving me these dirty thoughts
#5 ls2lxhatch
  • 5,335 posts
Posted 09 October 2016 - 02:10 AM
The LSA is not a viable option in an LX in WA. Under the NCOP the maximum forced induction engine capacity for and LX is around 3900 cc.
When an LS engine is mounted in a LX the centreline of the crank is typically a bit higher than the centreline of the 355 crank. This lifts the transmission a bit higher behind the LS than it is behind a 355.
Transmissions that just clear the top of the transmission tunnel behind a 355 will typically have tunnel clearance problems behind an LS engine.
I think you will find the 6L80e will drag on the ground.
Maintaining 100 mm ground clearance with the 4L64e is difficult enough. The transmission tunnel requires a fair bit of massaging to make the 4L65e fit behind a LS. I decided it would be easier to fit a new tunnel instead. The 4L80e is bigger everywhere.
#6 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 09 October 2016 - 09:27 AM
Yes i cut the floor ....i raised the tunnel hight for clearance to get the box at the correct angle
and as i said every thing you touch has to be modified
there is a lot to consider like wiring clearance issues fuel system and many more
#7 _LX355SLR_
_LX355SLR_
Posted 09 October 2016 - 04:21 PM
thanks. the 4l60e i have is rated to 800hp so should be good for a stock LSA and im happy with the box. I know there is and extra bolt hole to fit the LS top but is this essential? and will my converter fit to the standard flex plate. i have seen the TCI flex plates that look like they take multiple types of converters
#8 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 October 2016 - 08:16 PM
Hi Peter, there's also the reluctor wheel tooth count to look at depending on which ecu you have, can you run the 4l80e of the gm ecu ? I know that you are going for 4l60e, which would be converted to a 65e stronger, yes tci do heaps of parts to adapt, if you're chasing 450rwhp easy with a Ls3 mate & they're a good price now new, just cam, pipes & tune all good. Big Kev, can we ask how much the 6 speed was ? That would have to be the ultimate gearbox in a torana IMHO gary.
#9 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 10 October 2016 - 08:38 AM
Hey Gary
My gear cost about $4500 from the states about two years ago
at the time it was cheaper to buy this way than buy here from Mal woods or Dellow
not sure about the prices theses days
#10 _LX355SLR_
_LX355SLR_
Posted 12 October 2016 - 10:45 AM
to blokes that have modded the tunnel can you still fit the factory console in?
#11 _LS2 Hatch_
_LS2 Hatch_
Posted 12 October 2016 - 06:16 PM
Nope
Not if using a T56
The auto I think you may be able to
#12 _bmcgtr_
_bmcgtr_
Posted 17 August 2017 - 12:14 AM
Hi guys. Any updates on fitting a 6L80 into LH-LX? Pics would be great
#13 _rga5000_
_rga5000_
Posted 03 January 2019 - 06:42 PM
Just found this thread, has anybody had any luck fitting the 6L80 into LH-LX? Just bought a 2007 ve SSV to get all of the running gear from.
#14 roxiedog
roxiedog
  • 20 posts
  • Name:terry
  • Car:LX
Posted 25 October 2020 - 07:55 PM
I would also like to know how the 460le goes in and what hurdles do you have to go through?? I was thinking of a Rod Shop conversion kit. Has anyone used them before??
#15 rexy
rexy
  • 3,767 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 26 October 2020 - 04:01 PM
If you are handy with tools and/or fabrication or stinking rich then anything is doable.
