hg/hk/ht disc hubs ?
13 replies to this topic
#1 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 20 October 2016 - 02:57 PM
Are the disc brake hubs from HG / HT / HK holdens the same as LC / LJ disc hubs ?
#2 piquet
piquet
  • 857 posts
Posted 20 October 2016 - 04:18 PM
I dont now for sure but I would think thay might be as the same wheel bearings fit HK,T,g and LC/LJ torana
and the disc is located the same way.
#3 dattoman
Posted 20 October 2016 - 04:53 PM
I have some HT ones... if you have a Torana one we could compare
#4 S pack
  • 15,745 posts
Posted 20 October 2016 - 05:00 PM
AFAIK, but I could be wrong, the HK,T,G disc hubs are not the same as LC-LJ.
They use the same wheel bearings and mount the same way to the rotor as the LC, LJ but the stud PCD is ever so slightly different.
From memory a HK,T,G 14" rim will fit onto an LC, LJ hub/axle but the studs are not centered in the stud holes in the rim..
Edited by S pack, 20 October 2016 - 05:01 PM.
#5 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 20 October 2016 - 05:04 PM
narr dont  have any LJ ones
#6 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 20 October 2016 - 05:10 PM
i never heard that before , I always thought they are the same pcd .
Used some hg rims on my uc and they seam to fit alright
#7 S pack
  • 15,745 posts
Posted 20 October 2016 - 05:13 PM
That's what I remember but as I said I could be wrong.
#8 limo
limo
  • 2,673 posts
Posted 20 October 2016 - 06:32 PM
I have Torana drum brake hubs on my 6x4 trailer and 14" rims from HK T G, they fit OK
but it's a trailer
#9 Dr Terry
Dr Terry
  • 3,329 posts
Posted 28 October 2016 - 07:15 AM
The answer is yes & no !!
The part number for HK front disc hubs is 7435327. This changed to 2808760 for HT & HG, the only change being slightly longer wheel studs to suit the later wheels & nuts.
This is the same part no. as LC/LJ 6-cyl Torana.
BTW, to my knowledge all Holdens from FE to HG & all Torana LC/LJ 6-cyl & all LH/LX/UC have the same stud pattern PCD of 4.24".
Dr Terry
#10 _Bomber Watson_
Posted 28 October 2016 - 07:38 AM
Sorry to nit pick, but is 4.24" a typo terry?
Thoight it was 4.25".
#11 dattoman
Posted 28 October 2016 - 09:08 AM
It actually 4.24 Bomber
I had a pair of hubs that were actually HQ pattern....
Hub has a Holden # on it 7432118 (might be a B at the end)
Even has HOLDEN cast in it
Couldn't figure out their origins
#12 yel327
  • 13,721 posts
Posted 28 October 2016 - 10:13 AM
We were talking about something possibly relevant to this the other day Datto. A friend swears from photos that some of the South African assembled HK-HT look like they have Chev stud pattern. Many of these cars had locally manufactured stuff (in South Africa I mean), like the 250ci Chev 6cyl and Borg Warner rear axles. It is possible that hub is for one of these.
#13 _Bomber Watson_
Posted 28 October 2016 - 05:01 PM
Well there ya go, i've always called it 4 1/4" PCD.
Yet another myth that I have been accidentally spreading.
#14 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 30 October 2016 - 06:18 PM
ROH wheels made the wheels for GMH, based on blueprints provided by GMH. Guess what stud pattern ROH advertise?
