I am in need of some help before I do the unthinkable.
I have built an engine with the assistance of a mechanic and we are having major issues with getting oil pressure. The motor has been built for NOS so bearings have a bit more than normal tolerances. I am also running an ASR drag racing sump and modified High Flow JP oil pump. The oil I am using is a Penrite 15w50 Racing 15 Full Zinc oil which was recommended to my by the engine machinist.
After 2 nights of trying to get oil up the pickup we are still unsuccessful. We have added another 1L to the max level to see if this will help as well as being done during our tests so far. We packed the pickup with vas as well as the pump. We have since checked the pump which is creating suction and pressure to push it around. We removed the pressure gauge attached a fitting to it along with a tube full of oil and used air pressure to try and help get things moving but no luck.
We have been told to hook up a secondary oil pump or even just hook it all up and start the bastard but I really don't want to Chernobyl this motor.
Does anyone have any other ways or problems they have found with the lack of suction pressure from the pump etc and a way to rectify it. Photos would be a great help also
