Truetrac banjo or BW (std ls1 LJ)
9 replies to this topic
#1 _stapla22_
_stapla22_
Posted 01 December 2016 - 12:45 PM
Hi Guys,
Just looking at diff options again.  Putting a stock LS1 into a LJ.
Originally I decided on BW so I purchased a LSD solid diff out of VP commodore. I was going to get rodtech (SA) to modify the BW for around $1000.
I already have a banjo in the car with HQ pattern and HQ brakes.  I wanna keep the HQ pattern and recently found the thread by agent34 on banjo truetrac and custom axels.
What would you guys suggest is the way to go ?
Peter.
#2 _LS2 Hatch_
_LS2 Hatch_
Posted 01 December 2016 - 02:48 PM
Personally I would want stronger than both of them.
Easy to say its only a cruiser and won't get punished, but if that's the case why an LS?
Put something strong in and do it once.
My 2 cents anyway.
Good luck either way you decide. Sounds like a fun can on it's way
#3 ozyozyozy
ozyozyozy
  • 953 posts
Posted 01 December 2016 - 11:03 PM
Yeah kind of agree with LS2 hatch, if your going to the lengths of fitting an LS.
Id say no to banjo in any form with that motor.
#4 Bigfella237
Posted 02 December 2016 - 12:04 AM
+2c from me too, $1000 won't quite buy you a converted 9" but it's better to put it toward something stronger rather than tear it up the first time you "do a Grant" :burnout: and side-step the clutch @ 5000 RPM!
If money's tight you can always buy the converted 9" housing and axles but just throw an el'cheapo one-wheeler centre from a wrecking yard in for now, then play with gearing and 'limiting the slip' later when all the other bills are out of the way? So long as the axle spline count is correct of course.
As much as I hate to recommend a ford product, the 9" is basically "industry standard" these days, you could convert something like a Chevy 12-bolt but they're a lot harder to find parts for second-hand. Strange Engineering also do a banjo-style carrier for a 12-bolt centre but it fits into a 9" housing anyway so I don't really see the point?
The only saving grace is... you can actually build a complete 9" diff these days without actually using any ford parts, so is it technically still a ford diff? (That's my argument anyway and I'm sticking by it)
#5 _LS1 Taxi_
_LS1 Taxi_
Posted 02 December 2016 - 12:10 AM
Being anti ford is gayer than being into men.....IMHFO.
Grow up, it's 2016 and this shit isn't being made here anymore. The old fords and vals are an important part of our motoring history.
#6 LXCHEV
LXCHEV
  • 3,653 posts
  • Car:'76 LX - 383 Chev
Posted 02 December 2016 - 06:47 AM
Haha, agreed. People have been using Ford 9" parts in Holdens now for such a long time, that it's actually become a tradition in itself. If you're not in on it, you're missing out. Not to mention the sheer common sense of it too, superior upgrade and universal readily available parts.
#7 gtrboyy
gtrboyy
  • 3,241 posts
Posted 02 December 2016 - 08:36 PM
B/w commo diff if want to keep the weight down & rear disc conversion.Crewman diff if want something even stronger if anti-ford & something little bit lighter.
Had b/w in lc gtr no issues abusing that although got 9" in tubbed commodore....although heavy feels practically unbreakable
#8 ozyozyozy
ozyozyozy
  • 953 posts
Posted 03 December 2016 - 12:22 AM
9 inch is a big centre to fit into an LJ, i would kind of side with a borg warner with a kaaz LSD.
If you think you will want more power later, be honest with yourself, then go 9 inch.
They are 9inch by name only now, nothing ford about them, such a large aftermarket industry supplying them.
#9 rexy
rexy
  • 3,777 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 03 December 2016 - 03:05 PM
Spend the money once. I have nine inch setups in both my LJ coupes. Trouble free to date. Plenty of space to fit one in.
Piss easy to change the centre yourself if you want to try a different ratio.
#10 _Last-Rites_
_Last-Rites_
Posted 16 December 2016 - 01:24 PM
Contact Chris's Diffs and tell him ur application and power outputs. He can do u a great custom diff at a reasonable price. A lot of cars in Darwin use his gear and are all happy!
Chris's Diffs +61387426216
