LJ Front Disc Brake caliper assembley diagram needed
9 replies to this topic
#1 _ASLTO_
_ASLTO_
Posted 03 December 2016 - 09:28 PM
Hi All,
Could anyone please help me with getting an LJ front Girlock disc brake caliper assembly diagram, preferably an exploded diagram where I can see how all the bits and pieces "correctly" all assemble? including shims, spacers etc.
I've got the Girlock 6 cylinder type calipers, not XU-1 spec, I am going to fit the spacer kit to stop the squeaking I'm getting.
My 'old school' Father in law mechanic who is "almost" always right about all things mechanical seems to think he's got it right but I would like to double check all is as it should be.
Thanks'Attached File  IMG_2686.PNG   244.48K   9 downloads
#2 dattoman
Posted 03 December 2016 - 09:48 PM
So your not going to use the wide XU1 disc ?
#3 _ASLTO_
_ASLTO_
Posted 03 December 2016 - 09:59 PM
Hey Neil,
No, I've already replaced the rotors for a decent DBA type though they were the standard thickness but the heat treated version, decent pads, it pulls up great.
I want to get rid of the slight squeak and double check the father-in-law put the calipers together correctly.
Thanks'
#4 dattoman
Posted 03 December 2016 - 10:06 PM
OK
That kits not much good to you then
All you will use out of it is the shim plates that go behind the pad
Theres no use using the longer bolts and spacer plates without the thicker disc
The orings aren't required without the plates
The 2 top shield plates might not fit the narrower caliper (but worth a try)
The 2 stub axles spacer plates were only used on Monaros not Toranas to centre the caliper over the disc
What your missing though is 4 pad pins to hold the pads in... and the R clips to hold them (numbers 2 and 3)
If you have squeaky brakes now and no pad shims... thats a common problem
Attached File  lc caliper.jpg   90.83K   23 downloads
#5 _ASLTO_
_ASLTO_
Posted 03 December 2016 - 10:14 PM
Thanks Neil your a bloody legend!
Yeah I've got the new pins & clips and I was under the impression that all I needed was the shims to stop the squeak and now you've confirmed that.
Just out of curiosity, is that diagram from the LJ shop manual? is this something I can buy ?
Thanks' again !
#6 dattoman
Posted 03 December 2016 - 10:22 PM
The manuals pop up now and then
Theres a download somewhere here where you can grab it all on your computer and print pages as needed... or the lot if your keen
Skapinad had them
Thats actually from the LC parts catalogue used by dealers
#7 dattoman
Posted 03 December 2016 - 10:27 PM
http://www.ebay.com....ekAAOSwcUBYP7Ab
#8 _ASLTO_
_ASLTO_
Posted 03 December 2016 - 11:22 PM
Thanks again Neil,
I might just buy that one on eBay, if I'm lucky enough to be the highest bidder.
#9 dattoman
Posted 03 December 2016 - 11:25 PM
Don't pay too much
Theres a clown there trying to get 600 for them... don't let the blood rush to your head
#10 _ASLTO_
_ASLTO_
Posted 03 December 2016 - 11:46 PM
Might be better if beg Adam to send me a copy.
Thanks again Neil !
