Rust converter
3 replies to this topic
#1 _Tic toc_
_Tic toc_
Posted 15 January 2017 - 10:27 PM
Has anyone used dioxydine before I have a Lc with surface rust and pitting on the roof it has no paint only rust any ideas on the best way to treat it so it never comes back
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 16 January 2017 - 01:11 AM
That will convert the rust, I used it back in the early 80's. But it's no good if left out in the weather or for a long time. Did you have a look at the following thread?
http://www.gmh-toran...ust-convertors/
And welcome to the mad house. :D
#3 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 16 January 2017 - 07:16 AM
I have always sanded the rust off, wax and greased the panel, then de-oxidine, then metho, then wax and grease, then paint.
#4 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 21 January 2017 - 07:23 PM
If you use rust converter, say the likes of rs1 for an example, clean it completely off after 24 hours wax & grease remove & epoxy etch the bare steel, MAKE sure that the epoxy etch primer has metal protection properties, sikkens ep & baslac both do. Otherwise you are wasting your time and money. Gary.
