Wilwood master cylinder size lx torana
13 replies to this topic
#1 _fli304_
_fli304_
Posted 02 February 2017 - 11:40 AM
Im running the wilwood 320mm disc brakes all round and wanted to use the wilwood master cylinder without a booster. Has anyone done this and what size master cylinder would best suit. Cheers
#2 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 02 February 2017 - 02:05 PM
What do Wilwood recommend?
I'm interested on this one day myself
#3 _fli304_
_fli304_
Posted 02 February 2017 - 03:11 PM
I got the kit from castlemain rod shop and they said 7/8 but i wanted to see if someone has done this and how the brakes work and the feel of the pedal.
#4 Bigfella237
Posted 02 February 2017 - 04:41 PM
There are a heap of different considerations here, expected pedal travel multiplied by the pivot to pushrod ratio; the surface area of the master cylinder piston vs the total surface area of the caliper pistons in any given circuit; plus pad knockoff and caliper flex (how far the caliper pistons need to move before braking occurs) etc.
Generally speaking, the bigger the master cylinder piston diameter, the less pedal travel is required, but more pedal pressure. Or a larger fulcrum on the pivot ratio can also increase pushrod pressure, but in turn increases pedal travel. You will find that Torana brake pedals from unboosted vehicles had their pivot ratios setup differently from boosted systems, but finding one of these may be next to impossible?
With unboosted disc brakes you will likely want to keep the master cylinder diameter as small as you can without getting into excessive pedal travel as you're gonna need all the mechanical advantage you can get.
Have you ever been towed in a four wheel disc braked car? Once the booster vacuum runs out you can just about stand on the pedal before anything happens!
#5 dattoman
Posted 02 February 2017 - 09:48 PM
Are you a chunky bloke or a lightweight ?
Standard Torana and usual recommened is 1"
But if you like the pedal lighter and more travel... try the 7/8
I prefer a firmer feel so I'd be using 15/16 or 1" or even 1 1/8" depending on the rest of the brakes
But I'm a chunkybum
#6 Bigfella237
Posted 03 February 2017 - 01:42 AM
I thought I'd seen an online calculator somewhere on the Wilwood site to work out what suits what, but I don't seem to be able to find it now?
I did however run across a datasheet for Wilwood's "Dynamic Bleed System" which I hadn't heard of before, looks very interesting...
#7 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 03 February 2017 - 11:43 AM
And what is that supposed to do?
#8 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 03 February 2017 - 12:41 PM
Add more unnecessary shit in your car by the look of it?
#9 _fli304_
_fli304_
Posted 03 February 2017 - 01:22 PM
Thanks for all the the replies fellas. I think ill just got the 1 inch. Fingers crossed. Cheers
#10 gtrboyy
gtrboyy
  • 3,241 posts
Posted 03 February 2017 - 01:23 PM
Try 7/8 if you can..think softer more travel might give it better pedal feel
Had kingy m/cyl then xb falcon with twin piston fronts/single rears,as expected pedal was rock hard..I thought it was fine but everyone else thought car would either not stop or pushed too hard they'd go through screen but really all they'd end up with is sore leg.
I'm 125kg so wasnt a problem with concrete pedal except barefoot driving.
Edited by gtrboyy, 03 February 2017 - 01:25 PM.
#11 Bigfella237
Posted 03 February 2017 - 02:46 PM
From the Wilwood datasheet...
The Wilwood Dynamic Bleed System (WDBS) has been designed for maximum use brake applications where severe
rotor, pad and caliper temperatures are maintained for extended periods of time. The WDBS allows small amounts of
brake fluid to be circulated within a closed loop system each time the brake pedal is depressed. This helps to eliminate
localized fluid boiling and build-up of gases within the brake fluid, resulting in a firmer, more consistent pedal. The
WDBS consists of two (2) one-way flow valves and a special crossover return tube to replace the bleed screws (refer
to the diagrams below). Systems for the Prolites, Integras GT III, GT 6000, GT, GN III, and most Superlite calipers
are “in-stock” items and readily available. Applications include both single and dual master cylinder systems.
#12 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 03 February 2017 - 05:23 PM
How would you balance front and rear disc
So theres another master that goes beside it
for rears?
#13 Bigfella237
Posted 03 February 2017 - 05:33 PM
Yep, that diagram was from a "Balance Bar Dual Master Cylinder Setup" but it would be no different with the separate circuits of a two-stage master cylinder.
From their documentation, they only mention this dynamic bleed system on the front brake circuit, I guess it makes sense that most of the braking is done by the front brakes so most of the heat would be generated by the front as well?
Although I see no reason you couldn't run it on both front and rear circuits, it just means you'd need to run extra "return" lines?
But yeah, what's next... if they're that worried about brake fluid temp, why not run a heatsink on the return to cool the fluid? :huh:
#14 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 03 February 2017 - 06:18 PM
Bigger brake ducts. Or ducks.
