350 holley fuel inlet pipe help
7 replies to this topic
#1 _livo74_
_livo74_
Posted 22 February 2017 - 03:47 PM
so, may of bought the wrong part for my torana for the 17th time.
this is the HUGE inlet it had on it
this is the new one purchased/fitted,
FUEL INLET 5/8 UNF FITTING WITH 3/8
http://www.ebay.com....=STRK:MEBIDX:IT
and i can't get the existing fuel hose to slip on, even with tad of grease and force
did i buy the wrong size? too big?
(the thread is right, though. guessed that right at least)
or,,
40 yr old fuel rubber hose to blame.
here it is next to the ryco z14 fuel filter and size that APPEARS to be the correct diameter for the rubber hose
heaps smaller "nozzle"
any help/thoughts appreciated.
___________
should i of bought this? i smaller? not really by much at all, best i can guage
and would the thread therefore not fit my holley, as is different
CARBURETTOR FUEL INLET FITTING 1/2" UNF 5/16 PIPE
http://www.ebay.com....016.m2516.l5255
Edited by livo74, 22 February 2017 - 03:48 PM.
#2 _Bomber Watson_
Posted 22 February 2017 - 04:34 PM
5/16" is the stock fuel line size.
And no, the second one will not screw into the holley.
Edited by Bomber Watson, 22 February 2017 - 04:34 PM.
#3 _livo74_
_livo74_
Posted 22 February 2017 - 07:42 PM
cheers bomber.
??so i need to buy adapters that enlarge the fuel line to fit the holley inlet i gather, as holley ain't stock
#4 rodomo
  • 18,050 posts
Posted 22 February 2017 - 07:44 PM
I'd fit the fuel filter before the fuel pump.
#5 _livo74_
_livo74_
Posted 22 February 2017 - 07:49 PM
was just putting next to inlet to show size difference, will be in standard position rodomo
will remove old hose and buy some 3/8th fuel line hose
Edited by livo74, 22 February 2017 - 08:16 PM.
#6 _76lxJAS_
_76lxJAS_
Posted 22 February 2017 - 09:27 PM
u could try soke the hose in a cup of boiling water first to soften up the rubber?
#7 _Bomber Watson_
Posted 22 February 2017 - 09:39 PM
I would put the fuel filter between the line off the chassis and the fuel pump.
Then I would get a brass 5/16" to 3/8" straight joiner, and a bit of 3/8" fuel hose, and stick that somewhere between the fuel pump and the carby.
#8 _livo74_
_livo74_
Posted 22 February 2017 - 09:57 PM
was wondering about heating it jason, might give it a go. FREE if works.
and bomber, cheers
that's perfect
http://www.ebay.com....NAAAOSwDN1UQKNB
and yes, fuel filter in standard spot
(although am considering replacing with, or adding a second "clear one")
