How do I check vin
Would like to check vin
11 replies to this topic
#1 _Peter_
_Peter_
Posted 24 February 2017 - 05:12 PM
I have a l34 that tags have been miss placed any way of checking for previous info on it old rego hel34 thanks for any help
#2 yel327
  • 13,754 posts
Posted 24 February 2017 - 06:16 PM
If it has lost its tags it's VIN is lost with the tags, and you need the VIN tag to get the PSN to identify the vehicle. If you have its engine number you may have a chance though.
#3 _Peter_
_Peter_
Posted 24 February 2017 - 06:55 PM
I have the vin number was seeing if there is l34 registry to see if it is listed on it thanks any info would be great
#4 yel327
  • 13,754 posts
Posted 24 February 2017 - 07:02 PM
If that is the case and you have the VIN recorded prior to losing the tags, just get the digits after the J and ignore the H on the end. Will look like J512345. People will be able to look the car up for you.
#5 _Peter_
_Peter_
Posted 24 February 2017 - 07:09 PM
Vin is what is stamped on body of car that you regester it with the number you are talking about is the body number from what I understand as or am I wrong
#6 yel327
  • 13,754 posts
Posted 24 February 2017 - 07:36 PM
Chassis number is stamped in the car. Body number is on the body plate (matches PSN part of VIN on LH). VIN is on the skinny plate, looks like 8D69ZEJ512345H.
#7 Bigfella237
Posted 25 February 2017 - 12:58 AM
This gets brought up so often that sometimes I wish there was a big flashing banner on the main page...
You're confusing the Holden VIN with the 17-digit ISO VIN that replaced chassis numbers on later model cars, the ISO VIN didn't become mandatory in Australia until 1989 (I think it was) although some imported cars had them some years earlier as Australia was a little slow on the uptake.
#8 hanra
  • 11,023 posts
Posted 25 February 2017 - 09:09 AM
Is this the same vehicle?
469AEAD1-0F53-4C2C-A8F2-314944CF9215_zps
#9 yel327
  • 13,754 posts
Posted 25 February 2017 - 10:39 AM
I had an L34 like this a few years back, that had been a stolen and recovered and was wearing SLR5000 ID plates. I wrecked it out maybe 3-4 years ago and the body was cutup for body sections. I think all I kept was the front calipers for my HK. The rest including a lot of mint original bits went to help restore other cars.
#10 _Peter_
_Peter_
Posted 26 February 2017 - 06:53 PM
Thank fellas for your help things are looking promising been contacted by previous owner looks like another l34 saved
#11 yel327
  • 13,754 posts
Posted 27 February 2017 - 07:01 AM
Does he have the tags for it?
#12 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 27 February 2017 - 07:28 PM
Can you read the chassis number, would it start with ALH 007, cheers jeff
