![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Body ID number
_Marko74_
Posted 23 April 2017 - 02:13 PM
_Axewound_
Posted 23 April 2017 - 02:17 PM
_Axewound_
Posted 23 April 2017 - 02:21 PM
B is for manufactured in Brisbane, doesn't have a VIN I'm guessing?
Edited by Axewound, 23 April 2017 - 02:32 PM.
_Marko74_
Posted 23 April 2017 - 02:28 PM
_Axewound_
Posted 23 April 2017 - 02:32 PM
http://www.canberrat...com/info/id.htm
Edited by Axewound, 23 April 2017 - 02:33 PM.
Posted 23 April 2017 - 02:40 PM
Hi
That is the Chassis Number - it tells us nothing except it is Brisbane built around Jan 1972. The tags will identify it correctly.
Bazza
_Marko74_
Posted 23 April 2017 - 02:45 PM
_Marko74_
Posted 23 April 2017 - 02:53 PM
Posted 23 April 2017 - 04:59 PM
Is it still able to be registered if he doesn't find the 3 tags?
Mark
As far as I know, all state motor registration authorities go by the stamped chassis number. I would be best to check with them first.
Bazza
Posted 23 April 2017 - 07:04 PM
The authorities don't give a rodent's rectum about the VIN & Body plates, they only contain internal information relevant to GMH.
I'm unsure about other states (I think they're mostly all the same) but in NSW you can register a vehicle without a compliance plate so long as that vehicle was manufactured in Australia and you can prove it has been previously registered with the same chassis number (ie. it was compliant at some stage).
_Marko74_
Posted 23 April 2017 - 07:12 PM
_LC_2DR_
Posted 29 May 2017 - 07:24 PM
What if you have no proof of it being previously registered?
Posted 29 May 2017 - 07:54 PM
I'm not sure? I'd be surprised if they couldn't find the chassis number on their computer system, unless the car hasn't been registered (or looked at by the police) at all in the last 30-odd years since they went electronic?
I'd guess that in a worst case scenario you could have an engineer re-certify that the car meets the ADRs from the manufacture date?
_LC_2DR_
Posted 29 May 2017 - 08:24 PM
Ok. So it seems like there could be multiple options depending on the situation. Thanks for your reply.
Posted 29 May 2017 - 08:30 PM
Posted 29 May 2017 - 08:31 PM
Yeah it's not the end of the world, privately imported cars get certified all the time and they were never even subject to Aussie Design Rules.
I'd try and bluff your way through the inspection first off, they'll either pass it or tell you what you need to do. The biggest stumbling block will be to determine the original compliance plate date?
