fibreglass bog
11 replies to this topic
#1 _Shelly`s LX_
_Shelly`s LX_
Posted 15 May 2017 - 08:01 AM
i received my crappy flare kit ..
weve cut and refibreglassed it to a useable lot..
not i need some ? fibreglass bog? were using diggers resin and hardener [bought in set] now i need some bogg to fill in little holes and cracks,chips on flares
can anyone tell me the name of it ?
i have looked into using talc powder as i was told this is okay BUT "no thanks" i want proper stuff and not car steel bogg either
thanks in advance
#2 fx48_eh64
fx48_eh64
  • 199 posts
  • Name:MrFX
  • Car:Fx
Posted 15 May 2017 - 08:11 AM
normal car bog can be used on fibreglass no problems, i used to repair boats and this was common practice, talc is used as a filler when smoothing off the outside of hulls etc, it simply makes the resin etc bulkier and lighter and go further
#3 LJ RB30
LJ RB30
  • 1,041 posts
  • Name:Trevor
Posted 15 May 2017 - 08:22 AM
Gorilla hair fibreglass bog
#4 _Bomber Watson_
Posted 15 May 2017 - 08:53 AM
If your just using it to to fill imperfections you definitely want regular car bog, which is in its most basic form is talc in polyester resin.
I would not use hairy bog unless your fibreglass is a bit thin and you want to stiffen it up.
#5 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 15 May 2017 - 01:39 PM
bog shouldn't be a problem , but the diggers resin i think is polyester
that wont be good if the flares are epoxy
check what it is on the can
#6 _Bomber Watson_
Posted 15 May 2017 - 04:54 PM
I highly doubt the flares will be epoxy?
#7 UCSLE
UCSLE
  • 715 posts
  • Name:troy
  • Car:Goggomobil
Posted 15 May 2017 - 05:36 PM
dont know but i wouldn't touch polyester stuff
would use epoxy , even if there are made from polyester
#8 _Axewound_
_Axewound_
Posted 15 May 2017 - 08:22 PM
Edited by Axewound, 15 May 2017 - 08:24 PM.
#9 _Shelly`s LX_
_Shelly`s LX_
Posted 16 May 2017 - 06:45 AM
i was told we could use talc powder but when i looked into it there were more odds against then there were for =powder soaks up water ?
and i didnt want to use normal bogg i am wwondering if there is a special fibreglass bog ?
i just payed $1400 for a whole new flare kit = so much wrong and in this kit i did order the 140 mm rear flares and no they only measure 130mm [ripped off]
#10 _Axewound_
_Axewound_
Posted 16 May 2017 - 06:57 AM
That sucks, which flare kit did you buy?
Sent from my Pixel using Tapatalk
#11 _Shelly`s LX_
_Shelly`s LX_
Posted 16 May 2017 - 07:12 AM
it was from a old guy in victoria just a private sale everyone talked his products up so i went that way =regrets
anyway im thinking i can always just buy a set of a9x 140mm and add them
what i have will do for now they are better than what come of her looking for the putty i found some on ebay 201652363076
#12 _Shelly`s LX_
_Shelly`s LX_
Posted 16 May 2017 - 07:49 AM
FIBRALĀ®: Sandable Glass Fibre Repair Paste found it
