HI, Looking at my parts book for WB radiator shroud it clips at the bottom and is screwed at the top of the radiator. Would fit with the current radiator in the car. This appears to be how the aftermarket ones are made. The issue I have, is that looking at the shrouds on sale, all seem to have the fixing holes on the sides, and there is no provision for that on the new radiators, nor does it show it on the original one. Here's a pic of one FYI. Am I missing something. Cheers Ron
WB V8 radiator and matching shroud issue
Posted 19 June 2017 - 11:06 AM
Posted 19 June 2017 - 03:24 PM
HJ/HZ had fixing holes on the sides, as per the side-bands that radiator uses.
WB uses a totally different radiator, hence different shroud.|
Hope that helps.
Posted 19 June 2017 - 03:35 PM
Thanks for that. So all those ads for HJ/HZ shrouds that include WB aren't correct. Any idea what a WB one looks like? I can't seem to see any other variations on the net. Or is there any early model Commodore ones that may suit? Cheers Ron
Edited by Cook, 19 June 2017 - 03:35 PM.
Posted 19 June 2017 - 04:04 PM
Yes and yes.
Basically, WB uses Commodore cross flow type radiator.
I can not tell you if both Commodore and WB shrouds are the same due to engine location may be different sorry as I have never tried to interchange them myself.
Posted 19 June 2017 - 07:30 PM
Thanks again. Your knowledge is invaluable as I was about to buy a shroud, which would not have been correct, but not the first time I have bought a wrong item.LOL I might wonder down to the local commodore parts man and see what I can sus out. Cheers Ron
Posted 19 June 2017 - 07:31 PM
Posted 19 June 2017 - 08:11 PM
Thanks again. I'm just a bit surprised I haven't come across a WB V8 specific shroud. Maybe they are a bit rarer than I thought. Should be plenty of WB Statesman with the same shroud? Cheers Ron
Posted 19 June 2017 - 09:05 PM
There's a bloke in Adelaide has one for sale on Gumtree. Reckons it is a WB V8 shroud. Looking at the mountings it def suits a WB or Commo crossflow radiator
https://www.gumtree....x-hz/1104384601
Another person in SA has a WB V8 radiator for sale.
https://www.gumtree....ator/1151008464
Edited by S pack, 19 June 2017 - 09:08 PM.
Posted 20 June 2017 - 09:03 AM
Thanks for that Dave. The shroud certainly looks the goods. Pity he isn't in Melbourne. I already have a radiator but no shroud and I think it will fail under pressure (haven't run the engine for long periods yet) so that is why I started looking with the view of getting both at once. Cheers Ron
