Oil for T5
9 replies to this topic
#1 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 19 July 2017 - 06:56 PM
Was told to use Dextron III for the T5 gearbox.
Doesn't sound right...any ideas?
#2 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 19 July 2017 - 11:38 PM
75w 90 full synthetic nulon if it's 1990 vn 304 style, check the nulon oil vehicle guide via Google easy as ! Gary.
#3 76lxhatch
  • 7,213 posts
Posted 20 July 2017 - 05:54 AM
ATF is correct. T5s have a friction lining on the synchros similar to auto clutches, and the tolerances are designed to suit auto trans fluid.
If you go with gear oil you will need to ensure that its slightly on the thinner side and use an additive that is suitable for the friction linings. But there's no need as they run nicely on the ATF they were designed for.
#4 warrenm
warrenm
  • 2,122 posts
  • Car:1972 LJ Torana
Posted 20 July 2017 - 07:52 AM
Whilst ATF is fine in most T5, I prefer to put a 75/90 trans oil.
#5 Balfizar
Balfizar
  • 496 posts
  • Name:Chris
Posted 20 July 2017 - 10:21 AM
Just a little something I pick-up in research for my T5
Update on Dexron VS Gear oil for NON-World Class T-5's:
Dexron-III ATF replaced Dexron-II in 1993. While Dexron-III meets or exceeds the previous specifications, the viscocity of Dexron-III is thinner than the original Dexron-II that was specified for the NON-World Class T-5. This thinner fluid is fine for the World Class T-5 with the lined synchro rings, but the NON-World Class T-5 with the brass synchro rings needs a thicker fluid to work optimally. As a result, Tremec has specified 30W MOTOR OIL for the NON-World Class T-5's. While Tremec has not published an official document about this, it is confirmed by an email dated 1/9/2012 from a Tremec Engineering/Support employee.
WARNING: Using gear oil or motor oil in a T-5 with the composite lined blocker rings found in the World Class T-5's will destroy the blocker ring linings over a period of a few months rendering those synchronizers useless.
Edited by Balfizar, 20 July 2017 - 10:22 AM.
#6 76lxhatch
  • 7,213 posts
Posted 20 July 2017 - 01:46 PM
Exactly, and the VN onward box is a World Class T5.
#7 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 21 July 2017 - 08:28 PM
Thanks guys, Thanks for confirming the original advice.
#8 Statler
  • 6,325 posts
Posted 22 July 2017 - 08:34 AM
Weird.
I had my VN T-5 rebuilt. My gearbox guru specified oil, not ATF.
I have recently fitted a 355/T-5 from a VR into my sons VL. It has oil also so that's what went back in it.
#9 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 July 2017 - 07:45 PM
When my t56 was rebuilt, i have run 75 85 full synthetic in it since, It's been all good, Trans shop said that it was much better than the atf in them & it's what everyone does in the us aswell, no problem with syncros all though i run a rip shifter & full braided hose setup, along with a xtreme clutch, works great. Gary.
#10 76lxhatch
  • 7,213 posts
Posted 22 July 2017 - 09:10 PM
If you change the synchros to ones that don't have the friction lining then its basically just get the right weight gear oil. Otherwise as I first mentioned there are additives available that are suitable for the friction lining if you really want to run gear oil.
Seems a bit pointless though when ATF is cheaper and these boxes are perfectly happy running it.
