Turbo setup on 186 to 202 engine
14 replies to this topic
#1 _LJ_Trev_
_LJ_Trev_
Posted 04 March 2018 - 04:27 PM
(Hi All, Sorry I haven’t posted anything so these questions can be my first.)  I have a EH Holden Sedan that have been researching information on as I am about to start working on this car first. Sorry guys the LJ will have to wait.  My questions are related to turbo and supercharging 186 to 202 Holden engines. I have found some information on the Torana forum about this but it was an old thread.
Q1 - Can anyone tell me if they have made their own kits for turbo?
Q2 - Like intake and exhaust manifolds?
Q3 - What carbies that have used?
Q4 - What EFI system has been used?
Q5 - What Ignition systems are available like MSD?
Q6 - What Compression ratios work best without detonation?
Q7 - Has anyone used Forged pistons?
Q8 - Has anyone used the forged Conrods that are available?
Thanks in advance, Trevor
#2 _Bomber Watson_
Posted 04 March 2018 - 05:15 PM
1: yep
2: Stock blue motor intake and exhaust
3: 500 holley
4: VK efi would work fine to
5: Stock is fine, any msd will be fine. If going efi then just ge the computer to do it.
6:How long is a piece of string? Depends on your cam, how much boost you are running, what fuel you are running. I had 12 psi on 9:1, stock blue motor cam with 98 octane, could have taken more boost or compression.
7: not in this engine but JE slugs are cheap and easy to get.
8: Spool rods are cheap and easy to get, work fine.
Like anything there are a million ways to skin a cat. Above is how I did it quickly and nastily for shits and giggles, and not how I would do it a second time around with a higher budget. Basic principles of turbocharging any engine, as well as building any high performance engine apply to a holden six.
#3 _LJ_Trev_
_LJ_Trev_
Posted 04 March 2018 - 08:36 PM
Thanks Bomber Watson, That has given me some more food for thought. Just a quick explanation on what you would do on a higher budget.
Cheers Trevor
Edited by LJ_Trev, 04 March 2018 - 08:40 PM.
#4 limo
limo
  • 2,673 posts
Posted 05 March 2018 - 02:12 AM
I did 2 back around 1979
SS Hatch with 202, bought manifolds ( still in shed some where) Rymec I think
used decompression plate, motor standard parts
CD 175 carby draw through.
stock ignition
the other in race boat
186 with 202 pistons to drop comp (bored 179 block, still in shed also)
standard inlet, modded exhaust manifold to bolt on turbo
45 mm weber draw through
stock ignition
both motors were balanced by Repco workshop
both went very well
#5 _Bomber Watson_
Posted 05 March 2018 - 07:47 AM
Cheers Trevor
What is your end goal?
I kinda hinted that there are a million and five ways to do it.
I would personally not consider draw through as an option, but anything else is possible.
What do you want? 9 port head, 12 port head, jz head? Stock manis with a J pipe, log manifold, tube manifold? Carby or EFI, aftermarket or factory...
What fuel do you want to run? 91? 95? 98? E85?
How much power do you want to make? When do you want the boost to come on? When do you want to boost to peter out? What rpm do you want to rev it to?
How much do you want to spend?
Be honest with the above answers and I might e able to help.
#6 _Bomber Watson_
Posted 05 March 2018 - 03:36 PM
This popped up on facebok. Sorry I cant post picks on this forum nowdays.
‎Dan Alford‎ to Holden 202 red, blue and black motor appreciation group
3 hrs ·
Holden 186 intercooled Turbo engine
$5,000
Hoddle Grid, Melbourne
EOI only at this stage. Possibly selling Complete Engine Package.
Currently in a HR sedan
186 red engine
30/76 Garrett Ball bearing turbo
Custom manifold with 3" dump
Front mount intercooler + piping
Straight Gas carb, B2 convertor
Boost referenced
MSD 6al - 2 ignition
Gas / turbo custom ground cam
Roller rockers
12 port head with heaps of work
ARP head studs
Ready to transplant straight into your car.
Has not been on the Dyno but makes great power running low boost.
Still running and in car so I can take you for a drive.
Probably a lot I haven't mentioned.
NO TIME WASTERS PLEASE.
Located in Kinglake VIC.
Edited by Bomber Watson, 05 March 2018 - 03:36 PM.
#7 _lawn bowls_
_lawn bowls_
Posted 07 March 2018 - 08:17 PM
7.5.1 c/r if you use a carby they are set the same for off and on boost.they work on load so small cam tall diff gears,must use water injection or nulon prostrenght octane booster,if you want to is to go e85 if its available in your area.
#8 _Bomber Watson_
Posted 07 March 2018 - 09:15 PM
Wow, thanks for taking us back to the 1970s.
#9 _lawn bowls_
_lawn bowls_
Posted 07 March 2018 - 11:02 PM
no problems the 70s would of been the best years muscle cars not the hairdresser cars they have now,
#10 _Bomber Watson_
Posted 08 March 2018 - 08:06 PM
Yeah and now days a 3 door shopping trolley you can buy brand new for 3 months wages makes more hp per ci than the fastest production cars around in the 70's.
Technology has changed a lot and most of it filters back to our old dinosaurs, Why you would still frOck around with prehistoric ideas like 7.5:1 compression and water injection is absolutely beyond me. Hell even the "gotta use a small cam" idea was blown out of the water 30 years ago.
Edited by Bomber Watson, 08 March 2018 - 08:08 PM.
#11 _lawn bowls_
_lawn bowls_
Posted 10 March 2018 - 12:48 AM
because it works well ,
#12 _Drag lc_
_Drag lc_
Posted 10 March 2018 - 09:21 AM
aussie-t51r-feed-202ci-holden-6.353498
heres my build thread might be some light reading for ya..
cheers H
#13 _LJ_Trev_
_LJ_Trev_
Posted 10 March 2018 - 08:29 PM
Yes Drag Lc
I have had look at your build thread on the Torana and I am impressed whit you have done, and that's is coming from a old school Boilermaker.  Cheers LJ_trev
#14 _LJ_Trev_
_LJ_Trev_
Posted 10 March 2018 - 08:34 PM
Yes Drag Lc
#15 _Drag lc_
_Drag lc_
Posted 11 March 2018 - 08:46 AM
cheers thanks mate.
