Tri mattic transmission Id help,
6 replies to this topic
#1 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 06 March 2018 - 01:17 PM
Hi , have looked on Google , can't seem to find any reference for auto
ID F B
Pulled it off a 202 yesterday, any help appreciated , thx wazza
WB Holden:
FU 202 (3.3L) 6 Cyl with all diff ratios except 4.44:1
FV 202 (3.3L) 6 Cyl with diff ratio of 4.44:1
FX 253 (4.2L) V8
FW 202 (3.3) 6 Cyl with 4.44 diff and T-Bar Floor Shift
VB Commodore (Series 3 Trimatics):
FO 202 (3.3L) 6 Cyl
KO 253 (4.2L) V8
VC Commodore:
FS 202 (3.3L) 6 Cyl
FR 253 (4.2L) 8 Cyl
VH Commodore:
FY 1900cc 4 Cyl
LL 173 (2.8L) 6 Cyl
FP 202 (3.3L) 6 Cyl
FR 253 (4.2L) V8
#2 Balfizar
Balfizar
  • 498 posts
  • Name:Chris
Posted 06 March 2018 - 02:18 PM
FB - FC = HZ
Edited by Balfizar, 06 March 2018 - 02:38 PM.
#3 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 06 March 2018 - 02:26 PM
HZ ahh and its a trimatic yes  ?
what about the letter A
thanks in advance wazza
was this either floor shift or column ? or both ?
Edited by liswar, 06 March 2018 - 02:30 PM.
#4 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 06 March 2018 - 02:32 PM
Torque converter
#5 Bigfella237
Posted 06 March 2018 - 05:38 PM
Not sure about the "A", could be a revision or a gear ratio set, or maybe specify the torque converter, but that's only a guess?
Can't quite see from the photos but I'm pretty sure if the selector shaft is on the left (passenger's side) it would've been a floor shift or if on the right it would've been a column shift.
If it was still bolted up to it's original engine, the engine number and date stamp would be easier to pin down to a specific date. I don't have enough Trimatic serial numbers listed to be that accurate (and I don't think there were date codes on autos like there were on manuals).
#6 Kevrev
Kevrev
  • 420 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 06 March 2018 - 06:09 PM
The "A" is the calibration code, it should be marked as CAL. above the A
#7 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 10 March 2018 - 11:41 AM
CAL is A
Calibration code, any ideas any one ?
Thanks for the help gurus..
