I’m not a 100% sure on plumb to the remote booster.
I’ve done a quick diagram can any one tell me if the is correct way to plumb it all up??
Posted 25 April 2018 - 04:26 PM
Posted 25 April 2018 - 05:03 PM
I do not know how to add the proportioning valve in this set up but I would think if 1 side was boosted and 1 side was not the result would be the brake warning light will turn on. The light is set off by a pressure difference in the front to rear systems.
Posted 29 April 2018 - 11:34 AM
From the Hydroboost website. http://www.hydroboos...au/techtalk.htm
VH 40s and 44s can be made in a multitude of outputs and mounting configurations to replicate virtually any original equipment booster installation as well as being able to be configured to suit all types of original applications.
When choosing a booster for your car we need to know what type of foundation brakes you are using ie. whether you're using drums or discs, what size are your brakes, are you running a single or a split hydraulic system ,how much room do you have, are you going to mount the booster under the front guard,, or maybe in the boot or under the bonnet? All these facts need to be considered when choosing a booster for your car.
If you are using a dual hydraulic system in most cases you will need to run two hydraulic boosters, one for the front and one for the rear or in some cases if the balance of the front and rear is suitable you can boost the front only. Obviously a mastervac or mechanical booster is more suited to a dual hydraulic setup for many reasons, so room permitting, this is the way to go.
Posted 29 April 2018 - 11:13 PM
A road car should require both ends booster as per factory setup
The valve is just a switch block for the warning light and doesn't do any proportioning anyway
Are you doing this for rocker cover clearance with a V8 ?
Posted 02 May 2018 - 09:41 PM
Hey dattoman
Yes doing it for clearance.
Can i run a T fitting from the rear and front into the booster then another T fitting out from the booster into the proportioning valve as normal??
Or have heard a few guys running no booster at all
Posted 02 May 2018 - 10:37 PM
Hey dattoman
Posted 02 May 2018 - 10:49 PM
Connecting the 2 sides of the master cylinder together would not pass any inspection. There is 2 separate outputs from the master so that if you have a failure on 1 the other lets you stop the car. It has been required from about the HK to run a twin system. No booster would be better than connecting them together. May be a high brake peddle pressure needed to stop though.
Posted 02 May 2018 - 11:08 PM
Posted 04 May 2018 - 03:09 PM
all so if putting booster under the gard you should talk to hydroboost. he makes a fitting that makes the booster breath hot air from engine bay.. if dont may fill with condensation and rust out..i have my hose go over gear box and get the hot air from the extractors and cant see from the bay.. my to cents
