New pistons in 202 looking for piston to bore clearance assistance
13 replies to this topic
#1 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 18 May 2018 - 01:14 PM
Hi all,
Rebuilding the 202 and have got a set of new old stock Pistons they are
RA3300 060 same as I'm running
Bot.0015JE
Looking to work out the piston to bore clearance as they didn't come with any specs or paperwork
Hope some one can shed some light on this ,
Will be getting the new piston heads fitted to the rods next week
Thx wazza
Or if any one has a old spec sheet or can point me in the right direction, all help appreciated ,
And the heads tidy now too.
#2 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 18 May 2018 - 01:39 PM
Might not be of much help, but with cast pistons 3 to 4 thou should be fine. Forged you want an extra few thou, depending on whether NA or boosted you could go as high as 7 thou with forgies. A rule of thumb is 1 thou per inch of bore.
Disclaimer- I have no idea what the specified clearance for this particular piston is, so obviously if you can find the manufacturer specs this would be better than a rule of thumb guide.
#3 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 18 May 2018 - 02:14 PM
This should help. it seems ACL stamp clearance on the crown. I'm assuming this is piston to cylinder clearance.Attached File  Capture.JPG   165.75K   15 downloads
#4 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 18 May 2018 - 03:07 PM
Bot .0015 bottom clearance ?
Just found this as well ,
#5 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 18 May 2018 - 11:37 PM
It's stamped on the top. .0015"
#6 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 19 May 2018 - 01:25 AM
Thx ,
#7 _Agent 34_
_Agent 34_
Posted 19 May 2018 - 07:37 PM
bit more information to help gap set the  rings three thou per inch of bore as a start. make sure you measure at the bottom of the skirt not the top as the piston will have a slight oval below the gudgeon to set the bore and hone process measurements = looks like 15 thou clearance is specified . the ring land will have a step down so dont measure the boring size from that.
hope this helps - also a disclaimer - i'm no expert
g
#8 _Agent 34_
_Agent 34_
Posted 19 May 2018 - 07:40 PM
note that you can order either standard rings or get larger rings and file them back - I would get the file back ones and do it properly with a bit more effort.695H - on the screen shot
#9 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 20 May 2018 - 08:17 AM
.0015 is 1.5thou  not 15thou , .015 is 15thou. ,  usually a measurement of the skirt is taken at some specified point up from the bottom of the skirt ,take some measurements up the skirt and use the widest or biggest number or biggest diameter of the skirt and finish the bores to  skirt diameter plus clearance, a little
over won't matter as the clearance from new is generally a min. safe number that they specify.
#10 S pack
  • 15,752 posts
Posted 20 May 2018 - 08:44 AM
.0015 can also be expressed as fifteen ten thousandths of an inch.
#11 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 22 May 2018 - 01:20 PM
Hahahaha- if I was building this engine she would be a slapper hahahahaha... wow .0015 is pretty tight but if thats the spec thats the spec.
#12 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 22 May 2018 - 08:43 PM
.0015" would be about right if it were a Hypereutectic type piston, they run very tight clearances, but larger top ring gap due to them directing heat into the top ring and over expanding it, rather than the piston expanding as far as a traditional cast piston.
#13 _imperial engines_
_imperial engines_
Posted 27 May 2018 - 06:06 PM
ACL were always woefully tight with their specified clearance. 202 and 253 pistons . They spec 0.0015" but if your pulling numbers go more , anything around 0.003-4 fine. Often the rings supplied were file fit .
#14 liswar2
liswar2
  • 1,535 posts
  • Name:Wazza
Posted 04 June 2018 - 11:06 AM
Thanks all , will keep you up dated with engine rebuild as I progress,
