Lj steering rack inner oil pinion seal
7 replies to this topic
#1 Whittley
Whittley
  • 26 posts
  • Name:Jarrod
  • Car:Lj torana 2 door
Posted 13 June 2018 - 06:13 PM
Does any one know where I can get one of the seals number 29 in the photo either new or a retro fit job?
#2 rodomo
  • 18,051 posts
Posted 14 June 2018 - 11:15 AM
I went looking for these a year or so ago and the local bearing wholesaler found 2 off the measurement of the shaft and housing.
TC-NBR is the number on the packaging along with the dimensions: 0.562 x 0.860 x 0.156 in.
At the time he said they were the only 2 left within the company.
I think the biggest challenge you'll find is keeping oil in these buggers! I have found it near impossible to get the original clamps over the aftermarket concertina tie rod boots. These boots come with zip clips/loom ties which won't tighten up enough.
 I've been using grease.
#3 Whittley
Whittley
  • 26 posts
  • Name:Jarrod
Posted 14 June 2018 - 02:33 PM
Thanks a lot for the info rodomo!
Very helpful information.
Gives me a good start now. I'll do the ring around and see what I can find.
#4 bat 53
bat 53
  • 518 posts
  • Name:albert
  • Car:lc gtr
Posted 17 June 2018 - 10:19 AM
give this bloke a ring he is rebuilding my rack at the moment
rob at maddington power steering 0418945590
cheers  bat
#5 Whittley
Whittley
  • 26 posts
  • Name:Jarrod
Posted 17 June 2018 - 10:45 AM
Thanks mate I'll ring him next week to see if he can help.
#6 MustardGTR
MustardGTR
  • 243 posts
  • Car:72 GTR, 73 GTR
Posted 18 June 2018 - 08:29 PM
I rang all the locals shops very recently when chasing a similar seal for my UC rack.
The advice I got was LH-LX-UC ones are apparently discontinued.
Long story short is some rebuilders can't be bothered sourcing a $5.00 seal and work on the principle the grease will never leak out like the original oil.
Hopefully you can find the seal for the LJ, as it's definitely worth replacing even if just to keep water picked up off the road from entering the shaft at that point.
#7 rodomo
  • 18,051 posts
Posted 18 June 2018 - 10:08 PM
The reason these racks fail is that you cant keep the oil in them as mentioned above with repo parts.
Originally the concertina boot failed and the oil leaked out.
The top seal is hardly ever the problem, it is higher than the recommended oil level.
#8 IanC
IanC
  • 612 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 10 July 2023 - 06:52 PM
Old thread but. I put new boots on mine. And one leaked . I took the rack off, refilled the rack with oil. And put the leaking boot back on. It stopped leaking at the boot. But started leaking from the pinion seal. Is this what happens if you over fill as Rodomo has said ?.
