Bonnet latch spring and lever
8 replies to this topic
#1 lctriples
lctriples
  • 414 posts
  • Name:paul
  • Car:LC 2 door, HR prem wagon
Posted 28 September 2018 - 08:30 PM
Can anyone tell me how to remove bonnet spring and lever so I can get chromed and strip paint from bonnet? I think the spring unscrews but lever appears to be spotwelded in and I don't want to start drilling holes in the bonnet. I looked in service manuals I have but they didn't cover it, thanks paul
  • Attached File  263.JPG   67.41K   5 downloads
#2 Cook
Cook
  • 1,531 posts
Posted 28 September 2018 - 09:29 PM
Hi Paul,  Pretty sure you just unscrew the spring (flat head into the end of the assembly) from the captive nut on the bonnet.  Can't remember how I got the lever off, sorry.  Cheers Ron
#3 S pack
  • 15,740 posts
Posted 28 September 2018 - 09:43 PM
^^^ As above but loosen the locknut first then unscrew with a flat blade driver. Record the measurement from the bonnet frame to the flange for re-assembly.
To remove the lever you need to remove the pin upon which it pivots. You will see one end has a mushroom head and the other end is hollowed and peened over. This is the end you have to cut or grind away.
Edited by S pack, 28 September 2018 - 09:44 PM.
#4 lctriples
lctriples
  • 414 posts
  • Name:paul
Posted 29 September 2018 - 11:23 AM
Thanks guys, really appreciate your help, worked a treat and I even managed to salvage the lever pivot pin!  This topic might come in handy to other forum members in the future, paul
  • Attached File  266.JPG   97.11K   5 downloads
#5 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 29 September 2018 - 12:16 PM
Can you buy new pivot pins when it comes time for reassembly?
Cheers Graham
#6 dublinxu1
dublinxu1
  • 153 posts
  • Name:Brian
  • Car:73 Dublin Green XU-1
Posted 29 September 2018 - 03:59 PM
Cheers Graham
yep, on ebay. sorry can`t post link.
#7 S pack
  • 15,740 posts
Posted 29 September 2018 - 04:27 PM
Hi Brian, I didn't think replacement pins would be available.
https://www.ebay.com...PkAAOxy43FRZ8q-
#8 dublinxu1
dublinxu1
  • 153 posts
  • Name:Brian
Posted 29 September 2018 - 05:55 PM
Thanks Dave, used one of them on mine
#9 gad05
gad05
  • 421 posts
  • Name:Graham
Posted 30 September 2018 - 12:02 PM
Thanks Dave & Brian, I will pick up a couple of those.
