Thanks to Forum member jd lj (James) I made a pilgrimage to my local Jaycar store recently and picked up some LED's for the LJ instrument cluster and interior dome light.
I tried to take before and after pics of the difference with the interior dome light with the LED festoon but the pics inside the car are basically black.
So in lieu I grabbed a spare dome light and wired it up to my 12v power supply and snapped a few shots to show the difference.
Incandescent 36mm festoon bulb with diffuser
P1050094M.jpg 41.38K
30 downloads
150 Lumen 36mm festoon LED with diffuser
P1050097R.jpg 51.74K
27 downloads
Incandescent 36mm festoon bulb without diffuser
P1050096R.jpg 52.36K
24 downloads
150 Lumen 36mm festoon LED without diffuser
P1050098R.jpg 60.18K
24 downloads
Next is three types of T10 wedge white LED bulbs for the main instrument panel
left to right = 120 Lumen single SMD LED $12.95, 4 x SMD LED (unknown Lumen) $3.50, Single LED (unknown Lumen) $1.40
P1050105R.jpg 96.49K
32 downloads
T10 wedge LEDs Mounted in an old instrument backing plate
Left rear is the single LED, Right rear is the 4 x SMD LED and at front is the 120 lumen Single SMD LED.
P1050099R.jpg 78.08K
32 downloads
Apologies, I just realised I forgot to compare them with a std Incandescent T10 wedge.
I can say though the $1.40 LED is only marginally better. The main difference is the light is whiter. Well actually a bit bluer with the factory blue diffusers.
I will be using the 120 Lumen T10 wedges for the main instruments, 120 Lumen BA9S bayonet bulbs for the four 2" gauges and the $1.40 T10 wedges for the indicators, high beam and brake fail lights.
Another benefit of the LEDs is they don't generate as much heat.
I measured a std Incandescent T10 wedge at 46.5 deg C after 5 mins and the 120 Lumen T10 wedge at 36.1 deg C after 5 mins.
Edited by S pack, 07 October 2018 - 10:51 PM.
