Holden Red Motor
28 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 11:30 AM
Every motor has its flaws or weak points etc,the Holden red motor has always been regarded as a robust reliable motor ,wether it be. 149 ,161 ,186,202.Did any of these motors have known faults from factory or components within that failed often?Interested in any thoughts.
#2 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 12:06 PM
Under reasonable running conditions of course and not thrashed.
#3 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 10 November 2018 - 12:31 PM
Was there also the 173 ?
#4 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 10 November 2018 - 12:34 PM
All tough motors in there time. Personally I don't know of any common fault. You could drive any where with any one of those motors. Rainman
#5 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 12:35 PM
Yeah ,138,173,179 as well.
#6 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 10 November 2018 - 12:38 PM
138 was the grey motor ? Were there any other grey motors ?
#7 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 12:54 PM
Both Red and grey for the 138.
#8 LJ RB30
LJ RB30
  • 1,043 posts
  • Name:Trevor
138 was also a red motor
#9 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 10 November 2018 - 02:27 PM
Timing gear when they were the old fibre ones. Other than that very reliable
#10 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 03:44 PM
When did they phase out the fibre timing gear Danny?
#11 rodomo
  • 18,058 posts
Posted 10 November 2018 - 04:20 PM
That's a good question? I don't think they did but could be wrong. Most were replaced with alloy ones after they stripped.
Distributor drive gears used to strip too.
I have read here about 202 blocks cracking between the welch plugs.
#12 arrimar
arrimar
  • 3,134 posts
Posted 10 November 2018 - 05:02 PM
Great engines, kept 1,000's of mechanics employed for years.
#13 Dr Terry
Dr Terry
  • 3,341 posts
Posted 10 November 2018 - 06:40 PM
The Red 6-cyl engine was one of the most popular motors ever sold in Australia. They were simple, strong & reliable. With Bosch electrics & a Bendix-Stromberg carby (on most versions) they could be repaired & tuned by any novice mechanic.
The only regular failure that I can think of was that Red 202 pistons used to lose their top when hot & under stress. This was remedied around HJ I believe.
They were one of the first common 6-cyl motors to feature 7 main bearings. This made the bottom end very strong, even with cast iron crankshafts. This was evidenced by how successful the LJ 202 XU1 was in Series production & Group C racing.
As mentioned above they were produced in sizes ranging from 138, 149, 161, 173, 179, 186 & 202. There was also an even smaller 130 version for exports, where a particular country has a tax regime penalising engines over 2.2 litres in size. There were many versions of each size built, e.g. low comp, high comp, X2 & S etc.
The Grey engine used in 48 to EJ Holdens were made as 132.5i & 138i. There was no commonality of parts between the 138 Grey & the 138 Red, even their bore & stroke is different.
Dr Terry
#14 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 06:51 PM
Was the Holden red motor Australian designed or was it copied from America?
#15 S pack
  • 15,747 posts
Posted 10 November 2018 - 07:21 PM
Have a look at the Chevrolet 230, 250 & 292 6cyl engines. You'll get the idea.
#16 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 07:28 PM
Yeah right ,look very similar ,I wonder how they would have gone instead of the 202 with triples?
#17 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 10 November 2018 - 08:03 PM
I've read about the inline 6 cylinder chevs running triple dcoe's. When you think about how a Holden red motor or hemi goes with triples and a bit of work then surely the chev 6 has good potential. But I think that most of the cars in the US that had the inline sixes also were available as a v8 so if people want more hp then obviously a v8 is more a more common choice.
#18 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 10 November 2018 - 09:28 PM
There was a 201 buit too wasnt there,but not for holden vehicles..those chevy motor would b longer than the 6 .i wouldnt mind seeing one with a custom stroker crank and up the capacity ..thats got me thinking there was a couple guys making bigger capacity blocks based on the holden donk little while back..
Wonder if they kept going..capacity was somethng like 250 odd if i remember correctly..
Edited by madtoranajzedded, 10 November 2018 - 09:31 PM.
#19 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 10 November 2018 - 09:54 PM
This has come up for discussion before on the 201 ,I've never seen one but I believe may have been used in cement mixers etc.
#20 _imj411_
_imj411_
Posted 10 November 2018 - 11:52 PM
Imagine that in a LJ XU1 at a car show it would blow people's mind LOL including mine, cheers Aaron
#21 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 11 November 2018 - 05:51 AM
My father in law used to work at a concrete plant and has said that the mixers would need their red motors rebuild on a regular basis. I thought that maybe they needed tougher engines with more torque. Imagine seeing a concrete truck with a Holden red with a lumpy cam, some head work and a set of triple carbs hanging off it.
#22 RallyRed
  • 8,190 posts
Posted 11 November 2018 - 08:16 AM
uh oh,........................ a dozen or so rivet counters were just taken to hospital.  They are now in Recovery, following the nasty shock.
#23 _imj411_
_imj411_
Posted 11 November 2018 - 08:41 AM
Purrlx got it right about the timing gear. Great engines I couldn't kill my stock 202 in a LX SS in 370'000kms revved it to 5500rpm all the time went hard till I rebuild it for more performance. Ran 17.5 at heatchote allmost every time and I ran it heaps of times that day. Chirped 2nd and 3rd gear changes did at least 170 top speed all with well over 300000kms on the clock. Beat plenty of V8's VB Sle's, 289 XR Falcon, WB Caprice, 302 XC, I love 202's, cheers Aaron
#24 Indy Orange
Indy Orange
  • 2,971 posts
  • Name:Paul
Posted 11 November 2018 - 09:03 AM
And an XU1 transfer on the side of the front guard.
#25 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 11 November 2018 - 03:36 PM
Not sure when they were swapped.
