LH traumatic -> m21?
#1 _oikurtman_
Posted 21 August 2006 - 01:23 PM
thinking of swapping the trimatic for a 4 speed behind my 253.
What's the difference between an m20 and an m21?
Is the hole in the tunnel the same?
Will a 6cyl ratrap style clutch pedal fit the v8 cable setup?
They're the same length aren't they? no tailshaft mods needed?
Is the cross member the same?
Have to swap the flex plate for a flywheel right?
What's the go with the 'spigot?' i'm not sure what it even is exactly.
Anything else i should know?
I know there's a lot of questions
#2 _oikurtman_
Posted 22 August 2006 - 12:28 PM
I know at least a few of you must have done this job before!
#3 _flukey77_
Posted 22 August 2006 - 02:23 PM
Posted 22 August 2006 - 03:50 PM
Ok, ill try and answer your questions..i know this has been asked a thousand times before but i've heard a lot of different answers...
M21 has a shorter first gear i believe, so it takes off harder...
The Hole in the Tunnel is identical!
Yes the 6cyl rat trap set up works! i use it in mine!
Yes they are the same lengths, you can even still use your 6 cyl tailshaft
Cross member is the same!
Yes, u will need to get a Fly Wheel, and also you MUST buy a spigot bush to put on the inside of the flywheel so the end of the input shaft stays in position
The spigot bush is just a pourus (ceramic?) cylinder, with a hole in the middle of it, it just really holds the end of the input shaft so it stays square and doesnt break stuff! Remember to soak it in oil first!
Umm wat else....
Selectors are the same....
eerrrr nothing else i can think of right now....
good luck!
#5 _J&S Racing_
Posted 22 August 2006 - 05:02 PM
#6 _oikurtman_
Posted 23 August 2006 - 10:03 AM
So when buying an M21, I have heard of people wanting to know the cluster gear number. Why so?
Posted 23 August 2006 - 04:06 PM
Posted 23 August 2006 - 04:13 PM
#9 _oikurtman_
Posted 24 August 2006 - 08:57 AM
So a v8 M20 is no stronger than an M21? Just different ratios?
Later on i plan to put the 308 in. Would either box be ok for that?
Posted 24 August 2006 - 10:12 AM
253Torana SS said "M21 has a shorter first gear i believe, so it takes off harder..."
No, that's not correct, the M21's 1st gear is taller & doesn't take off as well. If you also run a tall diff (2.78 or 3.08) it pulls the s#*t out of the clutch on launch.
IMO the M20 has a better set of ratios for suburban traffic, especially if you see a lot of traffic lights. The M21 is 'close ratio' box & is more suited to high speed driving where you need 3rd to be closer the 4th. There is no difference in strength between any of the Aussie 4-speed regardless of their ratios.
Dr Terry.
Posted 24 August 2006 - 11:04 AM
Might also explain why car car is so shit to launch with the 3.08 diff!
#12 _oikurtman_
Posted 25 August 2006 - 06:46 PM
i also run a 2.78 diff, soon to be a 3.08. So an M20 would be a better option right?
My only worry is that i plan to swap to 308 eventually. But i haven't seen any 308 M20 setups. I've only seen 308 M21 drivelines. Would the M20 hack it?
#13 _MAWLER_
Posted 25 August 2006 - 08:51 PM
I much prefer the M20 (mind its like comparing sushi and sushini, they're both crap) because of the lower gearing. Had a mate who swapped the M20 in his 308 torana for the M21 and he regretted it every damn day, more sluggish. As for the higher gears/highway can't help.
JMO
Cheers,
#14 _UCV80_
Posted 27 August 2006 - 03:42 AM
the imput shafts are different lenths, if u got a v8 and want manual, u *need* m21
correct me if im wrong
Posted 27 August 2006 - 03:57 AM
if you going to spend money either get the tri tricked or go at least a toyota box or similar.
IMHO aussie 4 speed is crap.
Posted 27 August 2006 - 10:02 AM
just the same as you can get a 6 cyl M21.......M20 came in 6cyl and V8 versions with different input shafts to suite.
#17 _flukey77_
Posted 27 August 2006 - 05:41 PM
http://www.5speeds.com/muncie2.htm
Posted 28 August 2006 - 07:11 AM
That website is all about US Muncie gearboxes, nothing to do with Aussie 4-speeds.
The only commonality is the use of the PO numbers M20/M21/M22.
As I have mentioned several times before, these are only option numbers they are not identifiers. The HR-HG/LC Opel was an M20, a Gemini 4-speed was an M20, the HK-HG Saginaws were typed M21 or M22. So don't make the same mistake as the guys at Street Machine magazine & confuse US boxes with ours.
Dr Terry.
#19 _oikurtman_
Posted 29 August 2006 - 01:26 PM
The gearing sounds as though M20 would be best for me, correct me if i'm wrong. Just wanna know if it will last.
Why does everyone always mention toyota boxes when talking about aussie 4's? Easy conversion?
Posted 29 August 2006 - 01:36 PM
they are the same strength! there is no difference other than ratios!!Wasn't the M20 v8 only for 253's though? Liam, did your mate with the 308 and M20 ever have any problems?
Edited by makka, 29 August 2006 - 01:36 PM.
#21 _oikurtman_
Posted 29 August 2006 - 03:34 PM
So the M20 ratios would be better suited to city driving with a 2.78/3.08 diff?
Do both rat trap and cable clutches fit v8 bellhousings? what are the pros and cons?
Edited by oikurtman, 29 August 2006 - 03:37 PM.
#22
Posted 29 August 2006 - 06:39 PM
#23
Posted 30 August 2006 - 01:05 PM
#24
Posted 30 August 2006 - 03:16 PM
#25
Posted 31 August 2006 - 07:52 AM
