lower control arm bushes
28 replies to this topic
#1 _torriemick_
_torriemick_
Posted 23 February 2019 - 10:16 AM
hey so i have removed my front end to over haul as part of my resto so pulled everything apart pressed out all bushes had all blasted and powder coated that was easy
now putting back together have pressed in new nolathane bushes using a spacer so as not to crush control arm pressed in ball joint fitted back to main sub frame and have noticed the one bush on both side has come back out of control arm slightly and control arm is now turn on that bush not the bush moving in sub frame as desired
i do recall slightly straightening the bush section after pressing out old bushes but it was only slightly ( wish i didnt do that now but it was only a small tweak) has anyone else come across this problem as on my ohter caer i didnt have these prob would it be acceptable to re press bushes back in and put a small tack on them or is that a bit agricultural any help would be appreciated
#2 _Lazarus_
_Lazarus_
Posted 23 February 2019 - 01:21 PM
A lot of people around here are allergic to Nolathane
#3 _torriemick_
_torriemick_
Posted 23 February 2019 - 02:22 PM
would it have been better if i said whiteline
#4 _Lazarus_
_Lazarus_
Posted 23 February 2019 - 03:38 PM
Yeah I do prefer the Whiteline product. Most people will recommend you use rubber in the front end though.
#5 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 23 February 2019 - 03:59 PM
Most people with any sort of idea are allergic to nolathane because it is proven time and time again to be rubbish in almost all applications.
#6 _2 girls racing_
_2 girls racing_
Posted 23 February 2019 - 04:30 PM
Was just thinking about turning these up in hdpe today, will need to do some more research
#7 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 23 February 2019 - 05:46 PM
Nolathane bushes should place less stress on the lower control arms. Rubber bushes don't slide against the brackets on the K frame and so must deform as the lower arm goes through its range of motion whereas a nolathane bush that's been lubricated on the sides as they're supposed to be will rotate more easily against the K frame brackets placing less stress on the lower control arm to bush interface
#8 ozyozyozy
ozyozyozy
  • 952 posts
Posted 23 February 2019 - 08:50 PM
Street car use rubber.
If you do go to a poly bush superpro, the shells for the bush i find are far better quality.
It is a subject that comes up on a regular basis
#9 _Lazarus_
_Lazarus_
Posted 23 February 2019 - 10:31 PM
Sorry I don't use Whiteline, I use Superpro too. Can't comment on the Whiteline product as I haven't tried it.
#10 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 23 February 2019 - 10:56 PM
Another vote for SuperPro here
#11 S pack
  • 15,743 posts
Posted 24 February 2019 - 07:54 AM
+1
#12 _torriemick_
_torriemick_
Posted 24 February 2019 - 09:29 AM
okay so now we are gettin some where sounds like super pro are first choice followed by white line then standard rubber and keep the nolathane for throwing at the neighbours cat got it sorry was living in the past fitted the nolathane to a 308 lj i had ten year ago and they were fine with no real issues sounds like the quality has changed in the years gone by
So that said are the super pro ones of a similar texture/compound or are they made up of a slightly more forgivivng material
#13 S pack
  • 15,743 posts
Posted 24 February 2019 - 09:54 AM
Rubber is my 1st choice, however if I was going to use Urethane bushes then I would only use SuperPro.
The only Urethane bushes I have in my Suspension are the outrigger bushes. All the rest are rubber.
Personally, if your car is going to see mostly street use then stick with rubber.
Edited by S pack, 24 February 2019 - 10:01 AM.
#14 Bigfella237
Posted 24 February 2019 - 09:55 AM
https://superpro.com...n&cid=999500556
Superpro are available in three different compounds for Torana, depending on the suffix to the part number:
"-70K" = softest
"-80K" = medium
"-90K" = hardest
They recommend the 90K for the front LCA bushes and your choice of stiffness for the rear LCA bush and trailing arm bushes (all are the same physical size).
I thought it was Superpro who had the eccentric LCA bushes for extra castor but I can't see them listed now, or was that someone else?
#15 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 24 February 2019 - 10:53 AM
But for an application that has a weak bush to control arm interface I'd recommend poly.
#16 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 24 February 2019 - 11:32 AM
Whiteline make eccentric bushes for extra camber ect. Personally i don't think that there will be anything wrong with the whiteline, they're almost all from the same parent company, but vary in composition, I'm going to use full whiteline in the clubsport this year, but they're not really a hard bush. A lh i had in the past i was told to run, hard rack bushes, to keep the steering track stiff & on track & the rest rubber, although supposedly the outrigger bush affects the braking performance, which it does on commodore ect. Try it out & see how you go.
#17 S pack
  • 15,743 posts
Posted 24 February 2019 - 11:56 AM
Sorry, I don't follow what you mean by 'a weak bush to control arm interface'
#18 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 24 February 2019 - 12:04 PM
The bush is contained in one side if the lower control arm by a 4mm wide circumference of metal and on the other by a lip that's about 8mm wide.
An arm that has engagement all the way through the length of the bush would be much more resistant to the twisting force of a rubber bush than a pressed steel one like what you see with a cast member on a Commodore.
#19 LJ RB30
LJ RB30
  • 1,041 posts
  • Name:Trevor
Posted 24 February 2019 - 12:07 PM
Me too
#20 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 24 February 2019 - 12:08 PM
A rubber bush resists the turning force by vertue of the fact that you have rubber on steel that's squeezed together. Take a spring out of the front end of a rubber bushed Torana and move it up and down. Then do the same with a poly bushed and lubed Torana member and the difference is chalk and cheese.
#21 S pack
  • 15,743 posts
Posted 24 February 2019 - 12:39 PM
I've got a 30yo brand new never used pair of SuperPro SP1121-90K bushes that I had special order made in black.
They look to me to install and operate in exactly the same way as the original rubber bushes, the difference being the uretahane would make your suspension a helluva lot stiffer than a rubber bush ever will.
#22 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 24 February 2019 - 12:49 PM
Yes, stiffer as far as deformation is concerned but less resistance to rotation which leads to more accuracy
#23 S pack
  • 15,743 posts
Posted 24 February 2019 - 01:52 PM
So you're saying the urethane bush rotates on the centre tube which is locked into the suspension member?
Sorry but I'm not convinced. The bushes I have, the centre tube will not move, I cannot get it out to lubricate it and the bush will not rotate on the tube when locked into a vice.
SuperPro's instructions are the suspension bolts must be torqued to the vehicle manufacturers specifications with the vehicle on the ground at the normal ride height.
Sounds to me they operate in exactly the same manner as a normal rubber bush, only a lot stiffer, but as I have no personal experience with using these bushes I am only speculating.
#24 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 24 February 2019 - 01:58 PM
Yes the bushes rotate around the crush tube which is why you're supposed to lubricate them
#25 76lxhatch
  • 7,215 posts
Posted 25 February 2019 - 05:00 AM
^ That's correct, anything polyurethane in a moving joint usually operates more as a bearing than a bushing. Sometimes they can be pretty tight, which if you think about the comparison with bonded rubber, shouldn't matter too much.
Regarding the eccentric options, Noltec (light blue) used to do them years ago but have long since been bought out (I thought Whiteline had too?). Superpro doesn't offer eccentric but they are pretty easily machined to accept a slightly larger crush tube with offset hole, I've done this with the rear lowers on the front end to allow a bit more caster without excessive negative camber.
This shows the eccentric modification, and also note the grease grooves in the crush tubes:
http://www.gmh-toran...e-8#entry849759
