308/355 stroker engine build components
24 replies to this topic
#1 Cook
Cook
  • 1,531 posts
Posted 27 March 2019 - 09:48 AM
Hi all,  I am looking at a list of components provided by my intended engine builder and he has included some manufacturer options.  I haven't spoken with him yet to discuss pros and cons but curious to hear what you may have to say about the different brands, if that makes sense.
His brief is:
308 (QT) block stroked to 355ci
looking to get 450 - 500 hp at the flywheel
It will only be used as a cruiser
has to be driveable
Cheers Ron
#2 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 27 March 2019 - 11:15 AM
Howdy.
Only thing I would change is the crank from Scat to COME. Much better cranks.  I have had several 355's all with COME cranks and all above 450+hp and spinning to big revs.
Choice of cam for me is Crane as they are tried and tested. A F288 solid will get you 500hp with VN heads.  An F280 will get you around the 450hp mark.
Great little engines....
#3 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 27 March 2019 - 06:58 PM
Not sure you'd need the oil pump conversion, the std pump with some mods is plenty for the street.
Crow do good custom cams.  If you have the budget go hydraulic roller.  Guess it depends what heads / compression etc.
Switching to a Romac RO0220SA would save about 2 kg on the rotating assembly.
Wiseco also make decent pistons.
#4 Cook
Cook
  • 1,531 posts
Posted 28 March 2019 - 10:17 PM
Thanks for the feedback gents.  I will take these on-board when I meet with him next to finalise the build.  Cheers Ron
#5 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 29 March 2019 - 07:43 AM
Hi Ron, some other components not mentioned but key to the build:-
Cylinder heads? (VN or YT-3 or Torque Power CNC)
Inlet manifold (TP dual plane high rise)
Carby (Holley Ultra DP 750)
Sump? (ASR)
What machine work is going to be done to the block, any oil mods, main bearing work? (ARP studs as a minimum for intended HP)
Ignition system? (ICE/MSD)
Compression ratio? Which needs to be matched to the camshaft.
I don't think that those roller rockers are adjustable? So the valve train geometry and push rods length will need to be spot on. If ever you want to change to a solid cam then the rockers will need to be changed. Consider upgrading to adjustable rockers.
Agree with Lima31 on the oil pump. Modding the standard pump adds volume and pressure without adding load to the pump drive gears.
All of the other brands listed look good to me.
Cheers, Steve.
Edited by koalasprint, 29 March 2019 - 07:44 AM.
#6 Cook
Cook
  • 1,531 posts
Posted 29 March 2019 - 11:32 AM
Thanks Steve,
I didn't mention some of those other components but here they are:
Harrop dual plane inlet manifold
VN heads
Holley Avenger 770cfm carby
ASR sump
Ignition system - undecided but leaning toward ICE.
Comp ratio - aiming for 10:1.
As you thought those rockers aren't adjustable but I think I will stick with them to keep within budget.  I understand adjustable isn't mush more expensive but the additional work to accommodate them is.  I don't believe there is any "additional" work being done to the block etc. beside some port matching with the manifold.  Have dropped the Mopar oil pump to a hi flow pump.
The difficulty is finding the right balance for my application, within the budget, and keeping the beast driveable. Thanks again for your input. Cheers Ron
#7 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 29 March 2019 - 07:48 PM
On a street budget I would trade in the ICE ignition setup and the hi volume oil pump, and spend the money on oversize cam bearings, head and mains stud kit and the basic mains priority oil mods.
#8 _74LH_
_74LH_
Posted 30 March 2019 - 05:12 PM
Second the above, ICE ignitions are very expensive for street applications and in my opinion unnecessary. I'd go to a wrecker and get a Bosch commodore HEI dizzy for $100 (or less if you're lucky) then take it to someone like Performance Ignition Services, along with your cam specs and they'll set it up for around $350, at least that's what they charged me. You'll get a reliable spark and ignition timing and won't need to spend $1000+ for the privilege
Standard oil pumps work fine unless you're constantly above 5000rpm and pushing hard around corners - ie racing
Only other thing is make sure the block is sonic tested, a stroker motor on thin bores will have a short life. Also get block, heads and any other used parts crack tested. Small cost for peace of mind in the long term
Otherwise good luck and enjoy, currently waiting for my current stroker to be assembled!
#9 skap
skap
  • 1,123 posts
  • Name:Skap
  • Car:Mighty VN
Posted 30 March 2019 - 06:26 PM
What is the budget?
#10 ozyozyozy
ozyozyozy
  • 952 posts
Posted 30 March 2019 - 06:50 PM
My 2 cents, i would use the mopar oil pump, dont need high volume, the factory style oil pumps you can buy are mostly sub par, very hit and miss, factory was the best and cant buy new any more.
Dont use the all alloy romac balancer unless your using a heavier flywheel.
For a street cruiser, type of crank is not really a big deal, they will all do the job.
either use the durabond one piece cam bearing or a better option, i have seen really good results with wear using the coated cam bearing, unsure the company name.
770 carb may be a touch big, depending on what rpm engine can do.
For a cruiser, hydraulic flat tappet or better but more expensive hydraulic roller cam, less periodic maintenance.
#11 Big_Red
Big_Red
  • 79 posts
  • Name:Aaron
  • Car:LH Torana
Posted 30 March 2019 - 07:07 PM
I watched a YouTube vid some American guys did a comparison on different sized holleys. They had a 383 stroker SBC and used carbs all the way from a 500-1050cfm (from memory) there was very little gain from a 650 to a 750, over this Mark there was 1-3hp gained peak. The smaller carb should be more Streetable and make better power down low as it would have better air speed. I guess don't over cam or carb it and it will be a nice motor.
Edited by Big_Red, 30 March 2019 - 07:08 PM.
#12 gtrboyy
gtrboyy
  • 3,239 posts
Posted 30 March 2019 - 10:55 PM
vn rods or i beams...h beams are heavy are overkill for n/a streeter
modded std oil pump & oilways etc alot of good tricks on aussiev8 forum,,more about improving flow/volume & fixing common issues.
modded factory hei setup will be fine
You haven't mentioned diff gears/convertor/intake manifold/budget to get better answers tbh.
My vh sle is 10;7cr,f280/vn heads/harrop single plane,recurved hei/holley black  trimatic/4500 stally 4.56 9" drove nice for a weekender/cruiser although tad wild for most people
#13 Cook
Cook
  • 1,531 posts
Posted 31 March 2019 - 10:32 AM
Thanks again for all the comments and advise.  To be honest I was originally more keen to get feedback on the various manufacturer options listed than build type but appreciate the responses none the less.  To provide some further info FWIW;
budget is ~$10K
T400 trans and 9 inch diff with 3.50:1 ratio. Running 17" wheels
converter will be chosen to suit but not looking to go too big if I can help it
I had bought the carby some years ago and my tuner has said that it may be a bit big for the application but he will see
I agree that ICE ignition is expensive for what I need and that is why I haven't made a decision.  I had forgotten about Performance Ignition Services although I did have some earlier discussions with them so still on the radar
I had mentioned I have a Harrop dual plane intake manifold and will be staying with that to remain under the hood (no bonnet scoop)
Cheers Ron
#14 _74LH_
_74LH_
Posted 31 March 2019 - 08:11 PM
Just as a bit of a guide for you. I'm going a bit overkill on my bottom end of my 355 as I never want to have to touch it again and that alone will be close to $10k when completed. All up (including the heads, intake, ignition mods, engine dress etc) for mine I'm expecting anywhere between 10 and 12k all up. So be prepared for it to go over by quite a lot. And that's not including the cost of finding block and heads.
Another thing is a cost will be in finding a good block, people are starting to charge silly money for virgin bore red blocks. Be prepared to go looking at later model blocks (304) as they are more available and often cheaper. I'm using a VS series 2 block which has the advantage of thicker castings due to factory roller rockers and having a blind deck.
Again, just using my experience and opinion....and regurgitating information from my own engine builder haha
#15 Cook
Cook
  • 1,531 posts
Posted 01 April 2019 - 08:14 AM
Thanks Daniel.  Fortunately I bought the block and VN heads some years ago to use to dummy up some things, so as long as they are ok I don't have that cost.  I also have the intake manifold and sump, Cheers Ron
#16 Bigfella237
Posted 01 April 2019 - 09:34 AM
 ~ Be prepared to go looking at later model blocks (304) as they are more available and often cheaper. I'm using a VS series 2 block which has the advantage of thicker castings due to factory roller rockers and having a blind deck. ~
It's probably unlikely to happen but bear in mind that if someone in authority insists on checking for a newer block, you may end up having to meet the emissions standards that applied to the donor car it came from?
If that happens you will almost certainly need EFI, catalytic converters and a stock cam to pass the tests.
Whereas if you have an earlier block than the car it's going into, it's gonna be a lot easier to meet any standards that applied back in the 70's, if you even get tested at all.
#17 Cook
Cook
  • 1,531 posts
Posted 01 April 2019 - 09:53 AM
Food for thought Andrew. Cheers Ron
#18 TK383
TK383
  • 76 posts
  • Name:Tony
  • Car:Blue one
Posted 01 April 2019 - 11:12 AM
Scat chev journal crank
Scat Pro I beam rods with 7/16" bolts
Mahle pistons are great for a streeter, or CP is also nice, CP do a true flat top for holdens - available through precision.
Romac all steel balancer or powerbond street steel - forget alloy for street use.
Rollmaster red timing kit
Camtech for a flat tappet cam, don't use a shelf grind, get a custom, ask when you need specs.
Nason's sells some nice chilled iron foot flat tappet lifters.
Crane rockers, their energisers will do the job for you.
Stock oil pump modified, the Chrysler pump does not fix the issues because the issues are not with the pump.
ACL race bearings, any king bearings that get supplied by customers here get thrown in the bin or used for dummy up purposes, I will not use king.
Crane is a safe bet for springs/retainers/locks.
Harrop dual plane is weak, but I know your dilemma, a COME low rise single plane is a good alternative, I built a street 383 a couple of months ago with pocket port VN heads, baby hyd roller cam, COME intake & 750 carb - made 480hp & lacked nothing down low.
#19 _74LH_
_74LH_
Posted 02 April 2019 - 04:41 AM
Yeah I've asked a few people about that and haven't got a definitive answer. Seems depends who checks it at the authority.
I'm in Victoria so have VicRoads to work around, I believe all they do is check the block isn't stolen and that's it. The thing is all the blocks are the same essentially, there is no difference in the way of design that would affect performance or emissions from the block itself. Now arguably putting VN heads on does, so who knows where they land on stuff like that....Or if they're clever enough to spot the difference....
You could easily extend the argument to the intake manifold, carb, exhaust manifold, etc
I guess I'll see what happens with mine and report back
#20 Bigfella237
Posted 02 April 2019 - 06:52 AM
As I said, it's most likely that you'll get some govt key tapper that couldn't tell the difference between a HT Brougham and a VT Commodore block to save themselves, so long as nothing flags on their computer screen they couldn't care less.
I'm just saying if they do discover that the engine in a 1976 Torana is from a 1999 Commodore they may want to see more than a charcoal canister!
#21 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 02 April 2019 - 11:16 AM
i'm in Victoria and the car is on H plates. I changed my engine block for a 11QT(Statesman) block to a VT(1984 VK Commodore) with no issues. All I had to do was get a letter signed by the club verifying that the engine was period correct. I know, stunningly sensible huh.
#22 _LX57SS_
_LX57SS_
Posted 02 April 2019 - 08:39 PM
If your Keen, You could deck a Late Model block, Buy a worn out 60+ over Red Block with a Good number and then get Creative with a Die Grinder and Letter/Number stamps...
#23 Bigfella237
Posted 02 April 2019 - 08:45 PM
Then lube up your arse cause you're about to be somebody's bitch for the next 3 to 5 years!
#24 _LH8VD69_
_LH8VD69_
Posted 03 April 2019 - 05:12 PM
Haha I doubt it, didn’t some high priest get 3-5 for molesting kids? Can’t imagine getting the same for scribbling on an engine block
#25 _LX57SS_
_LX57SS_
Posted 23 April 2019 - 09:00 PM
Lol....  I get your point, But it its been going on for years. A engine builder told me that once an engine block has been decked, It can be Legally Re-stamped obviously with the number that was on it. I was at a All Holden car show and was suprised at the amount of 5.0l blocks i saw with qt engine numbers on them.
