Plastic behind door trims
Posted 19 April 2019 - 09:54 AM
Posted 19 April 2019 - 10:04 AM
There was a membrane glued to the doors in production. Kind of a plastic coated material, Typically a light grey colour but other members have reported other colours also used.
Easily torn when being removed.
Edited by S pack, 19 April 2019 - 10:06 AM.
Posted 19 April 2019 - 10:13 AM
It's there to stop drafts and moisture coming in around the door trim / inside handle / window winder
If you've ever had to drive a couple of hours in an old beater with a busted heater in the wee small hours of a freezing cold morning then you will appreciate those little pieces of plastic!
Posted 19 April 2019 - 11:11 AM
Posted 19 April 2019 - 11:38 AM
Posted 19 April 2019 - 03:43 PM
Posted 21 April 2019 - 11:07 AM
On more modern cars, a missing piece allows water to get into the car through the door trims.
My VT was filling up the foot well until I reapaired the plastic.
The top of the window frame relative to the bottom of the door shows the problem.
On a side note, would love to know what type of adhesive is used to keep them in place.
Non hardening and reasonably reusable
Posted 21 April 2019 - 01:32 PM
I just used this stuff on my ute doors and some Selleys butyl mastic. Would have been a bit easier to install if the plastic was a bit more workable and I was more careful/patient about it. Will probably use in on the Torana unless I see/hear of something better in the meantime. Cheers Ron
Posted 21 April 2019 - 01:34 PM
Posted 26 April 2019 - 03:52 PM
If you want to go the more expensive route I was just at Car Builders and they now sell the liners in a kit. Comes with a "tape" which looks like licorice and feels like firm mastic. You run this around where it needs to go and if you want to remove it later, I'm told you simply slice through it long ways (if that makes sense) and it will re-stick to itself when re-attaching. Cheers Ron
Posted 26 April 2019 - 07:12 PM
Sounds like a possible issue around your mirror seal, if you're leaking into the door, unless the belt strips are stuffed. They glue back together with loctite 406 if the rubber is separating.
Posted 27 April 2019 - 10:42 AM
The stuff to use is called Butyl or Butyl Mastic. Bunnings have it.
Edited by VDO, 27 April 2019 - 10:43 AM.
Posted 27 April 2019 - 11:12 AM
The belt strips arent a real close fit to the window, but they do touch.
There was enough seepage past it to allow water to enter.
The angle and shape of the door meant that the water was hitting the inside shell of the door and running through where the plastic should have been, down the door card then into the footwell. Was mainly during really heavy rain that it happened.
Light rain didnt seem to do it.
Took a while to chase it down, but as soon as I removed the door trim I found the problem.
It had had a window broken and replaced, and the lazy person that fitted it didnt bother neatly removing and reinstalling the plastic.
Once I repaired the plastic there was no further problem.
