can anyone recommend a cylinder head specialist to get a red 202 head done up to support air flow in a turbo to run 11s at the drags
cylinder heads
_lawn bowls_
Posted 21 April 2019 - 04:18 PM
Posted 21 April 2019 - 04:43 PM
HSD, head stud developments.. You wont need a crazy port job to crack 11s with forced induction, just a good flowing open chamber should do it.
_lawn bowls_
Posted 24 June 2019 - 12:11 AM
i do have a 161 head 1.4 exhaust 1.6 intake valves one piece stainless steel k liners and a flow sheet .600 intake 170 cfm .600 exhaust 147 cfm 51 cc chambers and good cylinder head specialist to get about .600 190 cfm exhaust and 72 cc chambers
forgot to say to suit turbo
Posted 24 June 2019 - 11:15 AM
I see you're in Queensland, 190cfm with a 9 port is not out of reach from most decent head porters. Anything over 200cfm is going to cost a fair bit but 190 in a 9 port should not be too hard to achieve.
Posted 25 June 2019 - 05:10 PM
you only need a simple low compression yella terra head to run 11's
_lawn bowls_
Posted 26 June 2019 - 11:26 PM
the problem is yella terra only makes 12 port heads only
Posted 28 June 2019 - 12:17 AM
just buy a second hand 9 port yella terra head and have it recoditioned
_lawn bowls_
Posted 28 June 2019 - 12:46 AM
i have already got a head with stainless steel valves and big valve springs so buying another head dosent make any sense.
_liam kelly_
Posted 03 July 2019 - 08:13 PM
Would have to say the head stud development guys know their stuff, I live in QLD and got them to do my head (12 port) . Cant believe how much louder the whole engine is with a good flowing head compared to stock.
Posted 03 July 2019 - 11:54 PM
well use the head you have it will easy run 11's with a strata turbo setup with .6a/r compressor housing and 1.15 exhaust housing and a turbo cam with high 230 at 50 duration and 480-500 lift,big webber carby or better still a holley.this has been done lots of times
Edited by turboman, 03 July 2019 - 11:55 PM.
_lawn bowls_
Posted 03 July 2019 - 11:57 PM
yes I know that my turbo has a .50 compressor housing and a 1.00 exhaust housing solid cam 242/242@50 .480 lift with 1.5.1 roller rockers I’ll be using Holley super sniper efi 20 psi 9 inch diff with 3.9 ratio 15 inch slicks 4000 rpm high stall converter from dominatorwell use the head you have it will easy run 11's with a strata turbo setup with .6a/r compressor housing and 1.15 exhaust housing and a turbo cam with high 230 at 50 duration and 480-500 lift,big webber carby or better still a holley.this has been done lots of times.
does this make sense??????
Posted 04 July 2019 - 04:39 PM
.50 compressor? id say it would be a .60.anyway you have more than enough to go 11's with what you have.any pictures of your motor and or car?
Edited by turboman, 04 July 2019 - 04:40 PM.
