UC Torana Caliper Torque Values
10 replies to this topic
#1 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 04 July 2019 - 07:03 PM
Just going through my so called "rebuilt" UC Torana calipers before I fit them to the car.
Was wondering if anyone knows what the factory torque values for the guide pin bolts, brake hose to caliper and anchor plate to steering knuckle were.
I thought I might as well do this one by the books if I can.
Thanks,
Greg.
#2 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 04 July 2019 - 07:13 PM
Also, anyone have any views on the quality of Protex brake rebuild parts
#3 dattoman
Posted 04 July 2019 - 09:29 PM
Torque = tight but don't strip them
Protex = about the same as everything else on the market nowadays
Just don't use their pads
#4 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 04 July 2019 - 09:33 PM
Pads are Bendix ultimate
Might have to hunt down such service manual for torque values.
Do you know if there's a download for the UC service manual. No doubt the parts manual won't have that info
#5 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 04 July 2019 - 11:11 PM
So looking at the VB Commodore service manual:
Unlisted - guide pin bolts
27-34Nm - brake hose to caliper
70-84Nm - anchor plate to steering knuckle
VT Commodore service manual
30-34Nm - guide pin bolts
So at this stage I think this is what I'll go with unless I can get the UC Torana values (I don't trust myself not to strip bolts without a torque wrench)
#6 I'm a Red Motor fiend
  • 767 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 06 July 2019 - 04:02 PM
I set my torque wrench to three blows with my hammer to the corresponding ring spanner 👍
#7 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 06 July 2019 - 06:05 PM
I suppose I could set it to stun.
By the looks of some of the fasteners that have come of this car someone set their torque wrench to full blast
#8 ls2lxhatch
  • 5,335 posts
Posted 06 July 2019 - 07:00 PM
The Gregorys UC Service Manual and the Gregorys LH/LX Service manual only list torque settings for the caliper mounting bolts.
UC is 105 Nm front caliper and 71 Nm rear caliper.
#9 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 06 July 2019 - 07:15 PM
That's a bit higher than for the VB Commodore which has a very similar caliper. Maybe the commodores a bit weaker in the mounting hole.
#10 Dr Terry
Dr Terry
  • 3,334 posts
Posted 07 July 2019 - 09:32 AM
UC Toranas got 2 styles of calipers. They started out with the PBR 'part alloy' (Dattoman's favourite). During 1979 they changed over to the Girlock 'Collette' type caliper similar to Commodore.
These will obviously have different torque figures for the 'guide pin'.
It also depends on which bolts they are referring to. There will be quite a difference between the guide pin figure between the different caliber types, however the mount bolts (to the stub axle) should all be similar for Torana. The Commodore mount to the strut will differ as it i a larger (metric) bolt.
Dr Terry
#11 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 07 July 2019 - 09:37 AM
I have the Commodore style calipers so should probably go with the 105Nm value then for anchor plate bolts.
As for guide pins, I think the VT Commodore ones are a little bigger if I remember rightly so their value might not be applicable to the Girlock ones
Edited by mugginz, 07 July 2019 - 09:38 AM.
