Steering binding up as the car heats up
16 replies to this topic
#1 Orange SS
Orange SS
  • 523 posts
  • Car:1976 LX SS Hatch
Posted 18 November 2019 - 01:54 PM
I have a strange issue that as my car heats up and the components in the engine bay heat up with the engine, my steering becomes tights and is binding up.
I have recently installed new bearings in the top and bottom of the steering column, and a new steering uni joint and about 2000 kms / 8years ago i had a reconditioned steering rack installed.
Has anyone had anything similar to this happen before? It turns fine when cold every time and only ever has this issue after its reached around 85-90 deg.
For finding out what may be the cause I was thinking of getting it to operating temp when its starts to bind, and then quickly unbolt the steering coupling or uni joint then turn the steering wheel - if it still binds its the column, if not the rack may be an issue with the steering rack.
My column also has an issue that the wheel can pull right out of the column while still attached to the top half of the steering shaft - is there something that can fix this?  whatever is on the inside of the column making it a collapsible column may also be the cause of this binding issue - does anyone have a pic showing what on the inside of the column?
#2 Shiney005
  • 9,703 posts
Posted 18 November 2019 - 04:28 PM
I had an LJ once that had a binding issue, and it ended up that the car had been in a big prang and the column had collapsed. The fix back then was to head down to the local tip and unbolt another one.
#3 ls2lxhatch
  • 5,335 posts
Posted 18 November 2019 - 07:23 PM
The top bearing in the coffee pot stops the wheel pulling out of the column. See this post for details.
http://www.gmh-toran...s-off/?p=356970
The most likely cause of the binding would be the lower steering column bearing heating up and seizing. You could try cooling the lower bearing to confirm.
There are some pictures of a dismantled column in this thread.
http://www.gmh-toran...e-2#entry602961
#4 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 19 November 2019 - 11:15 AM
There's a groove in the steering shaft just under the base of the coffee pot. It should have a cir-clip.
That cir-clip under the pot is what stops the top shaft from pulling up. Check to see if it's missing.
#5 Orange SS
Orange SS
  • 523 posts
Posted 19 November 2019 - 04:29 PM
thanks for the info guys.
I'll try putting some heat shield around the lower bearing and check out the top bearing and also for the clip under the coffee pot
#6 Trukir
Trukir
  • 9 posts
  • Car:77 LX Sedan
Posted 28 December 2019 - 11:16 PM
How’d you go here Orange? Mines doing the same thing, do you have the bottom roller bearing mod?
#7 Orange SS
Orange SS
  • 523 posts
Posted 28 December 2019 - 11:37 PM
I’m about to check/replace if needed my front right ball joints. I have put the rare spares upper and lower column bearings in a while ago & I still had the issue.
I’ve got the sealed type ball joints which I installed roughly 13 years ago. They would have some plastic internally which may have become heat damaged or just a failed ball joint. I think a ball joint with grease nipple & metal internals could be my best option if a ball joint is what’s causing the issue.
#8 Trukir
Trukir
  • 9 posts
  • Car:77 LX Sedan
Posted 29 December 2019 - 10:35 PM
#9 Trukir
Trukir
  • 9 posts
  • Car:77 LX Sedan
Posted 29 December 2019 - 10:44 PM
Be doing it all the time if it was a bj eh? Would enough heat get to it from headers?? Could a uni bind from the heat? Mines a chev and the unis are real close to the header tube.. i put the additional uni and shaft mod instead of the flex/nolathane joint, didn’t really make a difference, starting to think the roller bearing mod in the bottom of column is the problem.. but how many people have done that mod without issue..shedloads i reckon!!
#10 Orange SS
Orange SS
  • 523 posts
Posted 03 January 2020 - 08:53 AM
So its not the ball joints so it has to be either the steering rack or column.
So far I have replaced the bearings top and bottom in column, a new uni joint and NOS steering coupling, greased tie rods and ball joints and installed a heat shield on the steering shaft where the uni joint is.
Having the steering run within 15mm of the extractors certainly doesn't help but I think it may be the lack of oil in the steering rack that may be causing it to bind up. I'll put some oil in today and then take it for a drive & hopefully this will prevent the steering binding up. I hope there is no damage to the internals of the steering rack
#11 Orange SS
Orange SS
  • 523 posts
Posted 03 January 2020 - 08:56 AM
I'll also add that with standard torana front brakes my wheels get so hot I cannot touch them and water boils off them just from driving around town so that heat transfers through everything in the front end. Add in the engine and extractors it gets rather hot pretty much everywhere from the firewall forward.
#12 Shiney005
  • 9,703 posts
Posted 03 January 2020 - 11:50 AM
It will be interesting to see if it makes a big difference. Have you changed the steering geometry at all? Steering arms? How are your wheel bearings?
#13 Trukir
Trukir
  • 9 posts
  • Car:77 LX Sedan
Posted 04 January 2020 - 10:58 PM
Yeah, wasn’t thinking about brake heat.. I’m pulling the rack this week to rule it out.
#14 Orange SS
Orange SS
  • 523 posts
Posted 13 January 2020 - 09:28 AM
The steering /suspension setup on my Torana is all standard LX besides being lowered 1.5 inches.
I am getting my rack reconditioned / trying to find a UC rack which will hopefully help the issue.
#15 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 13 January 2020 - 11:14 AM
Does your car have a UC K frame?
UC racks use different sized bolts to LH/LX. I presume the rack bolt holes in the K frame are slightly different as well.
Edited by mugginz, 13 January 2020 - 11:14 AM.
#16 Orange SS
Orange SS
  • 523 posts
Posted 13 January 2020 - 12:53 PM
I have an LX k-frame but as far as I know the UC rack fits provided you use the UC bolts.
#17 Ando
Ando
  • 527 posts
Posted 13 January 2020 - 04:30 PM
Matt,
A mate had pulled his motor out by lifting the body off the K frame & motor. The uni joint bottom cotter pin was stuck fast so the top one was removed for separation.
When the body was lifted on the hoist, the uni & shaft didn't separate to easy as it should of if the btm pin was removed.
Nobody thought too much about it but when the motor went back in & was ready to drive. He experienced the steering binding up when it got to operating temperature!
We pulled the steering shaft out & it was straight but when he looked down the tube, it was bent at the bottom part of the expanded mesh area.
We couldn't see any visible damage from the engine bay side.
That mishap was enough to put the bearings out of alignment & bind up the steering when the motor reached operating temperature!
Once the tube was straightened & reinstalled, all was back to normal. Maybe it's worth a look into..
BTW; Some assume that the top & bottom bearings need replacing because they're sloppy. This not the case!!
Most times, all they need is a solvent clean & repacked with bearing grease. They're not a high speed bearing & being a little sloppy also aids with the prevention of road vibration reaching the steering wheel.
