LS Conversion (Radiator Hoses)
10 replies to this topic
#1 BENN0
BENN0
  • 80 posts
Posted 29 January 2020 - 03:31 PM
Im fairly close to finishing the LS conversion (long journey) and looking for any info on radiator hoses.
My radiator has the top house outlet on the driver's side, lower outlet on the passenger side.
Is there a hose from another vehicle that fits or is close to fiiting and cut be trimmed to suit?
Thanks in advance
#2 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 29 January 2020 - 04:55 PM
Not sure if anything off the shelf, others may know. But a good looking alternative is to get thin wall (sched 10) stainless steel pipe sections bent up to suit and use short straight hose sections at the ends to attach to pump and radiator etc. Need to ensure that the pipe also has the bump put in it to properly retain the hose and clamp on the pipe.
#3 BENN0
BENN0
  • 80 posts
Posted 29 January 2020 - 05:26 PM
Thanks for that.
Im trying to keep away from the cut and shut hose if I can (Top hose especially)
Ive seen a few pics of Torana's that look like they are running a similar hose to factory VX/VY hose (maybe cut down) Hoping someone here can confirm it.
#4 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 29 January 2020 - 11:22 PM
Do you need the lengths of the vx style hoses mate ?
#5 BENN0
BENN0
  • 80 posts
Posted 30 January 2020 - 11:58 AM
Yes please. From pics the top hose may be a little long "across" the radiator to fit the Torana but would be good to check.
#6 neglectedtorana
neglectedtorana
  • 1,057 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 31 January 2020 - 05:55 PM
Mine is the opposite, top hose on passenger side and lower hose driver's
Also I have a straight neck on the outlet from the thermostat housing on driver's side instead of the Commodore neck that points to the chassis rail
I bent a piece of wire roughly the shape I wanted and rummaged through the radiator hose shelf st supercheap until I found something suitable
#7 bat 53
bat 53
  • 521 posts
  • Name:albert
  • Car:lc gtr
Posted 01 February 2020 - 09:58 AM
i've always modified the radiator to fit the original engine hose
then cut the hose to suit
#8 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 01 February 2020 - 03:55 PM
I run VY hoses
Top hose is cut to fit a joiner with a gauge port of which i plumbed the steam lines to
Bottom hoses (2 piece) are just shortened and using a VY crossover pipe
If you don't want to cut and shunt the top hose you'll need to have your radiator modified to have a port for the steam lines
#9 BENN0
BENN0
  • 80 posts
Posted 05 February 2020 - 10:11 AM
Thanks for that.
I'll buy a set of VY hoses and run from there.
#10 Growla
Growla
  • 229 posts
  • Car:LX SL/R LS1 conversion completed July 2010
Posted 24 February 2020 - 03:32 PM
I used the sunbird hoses from Mackay Ch1015 for the bottom and top Ch1016. Near perfect for my set up. I did put a bleeder (similar to those inline temp gauge adaptor) in the top hose which made it 20mm longer.
The bottom hose was like it was made for it.
Edited by Growla, 24 February 2020 - 03:33 PM.
#11 BENN0
BENN0
  • 80 posts
Posted 24 February 2020 - 07:10 PM
Thanks! I’ll take a look at them
