Speedhut gauge conversion LX LH
8 replies to this topic
#1 _fli304_
_fli304_
Posted 08 March 2020 - 02:14 AM
Hi, I've recently done a speedhut conversion on my original lx dash cluster set Up with a laser cut plastic template. I have a spare template if someone wants to do a similar setup. Msg on 0402763697 or DM
#2 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 08 March 2020 - 07:07 PM
Nice work, well done!
I am not changing yet but Is it a cable speedo? What signal is the Rancho using?
Cheers, Tom
#3 _fli304_
_fli304_
Posted 09 March 2020 - 01:22 AM
Cheers, Tom
It uses a GPS unit which has a magnet and sits under the dash. Works perfect
#4 neglectedtorana
neglectedtorana
  • 1,054 posts
  • Name:Tom
Posted 09 March 2020 - 06:37 PM
Thanks,
My auto correct must have turned tacho into Rancho, sorry that bit didn't make any sense
#5 Racehatch
Racehatch
  • 1,028 posts
Posted 09 March 2020 - 07:04 PM
Can you confirm which gauges you went with (from the speedhut range)? How much did they cost as a set?
Thanks,
Sam
#6 _fli304_
_fli304_
Posted 09 March 2020 - 07:37 PM
Thanks,
Sam
Hi I purchased the following
3 3/8 GAUGES
Part numbers
GR338-QUAD-01
GRM338-GPS-03T
GR338-TACH-02
Cost was $770US
#7 _LXT333_
_LXT333_
Posted 10 March 2020 - 09:12 PM
This looks awesome.
The dash cluster is something I still need to address on my build.
I like this option.
#8 Marks LXTorana
Marks LXTorana
  • 158 posts
  • Name:Mark Grovenor
  • Car:LX Torana
Posted 03 April 2020 - 08:37 AM
Nice job, almost identical to the process I went through to install my Speedhut guages!
http://www.gmh-toran...-5#entry1016999
#9 _fli304_
_fli304_
Posted 03 April 2020 - 06:40 PM
Yeh I think this setup works really well and still looks factory style. Better then guages all over the dash
