4 cylinder to 6 cylinder conversion rego
Posted 31 May 2020 - 08:46 PM
Posted 31 May 2020 - 09:37 PM
Posted 31 May 2020 - 09:58 PM
There is a no tag option for original shells for rego too.
Posted 01 June 2020 - 10:22 AM
This may be a stupid question but, if the rails have been swapped, wouldn't it now have the six cylinder car's chassis number stamping?
Posted 01 June 2020 - 10:37 AM
Therefore its a 6 cylinder car with a 4 cylinder rear end. If worded that way you might have a better chance of rego?
Posted 01 June 2020 - 11:06 AM
Posted 01 June 2020 - 12:09 PM
As above. If it’s well done just present it and you should be fine.
Posted 01 June 2020 - 12:16 PM
Posted 01 June 2020 - 12:33 PM
The firewall forward is the 6cyl car so that holds the identity of the vehicle to be registered. If the 4cyl rear axle and trailing arm mounts were replaced (and they should have been) with the 6cyl items then the rear half is now effectively a 6cyl rear body.
Personally I wouldn't consider it as converting a 4cyl to 6cyl, rather it is repairing a damaged 6cyl model by performing a cut and shut using a 4cyl rear body section.
Edited by S pack, 01 June 2020 - 12:35 PM.
_LONA-CK_
Posted 03 June 2020 - 08:05 AM
There are a few hidden parts that will still give the back half of the body away as a 4cyl, if your not in the know of these body and did not do the conversion yourself. If you need help and want to know more just pm me and I will fill you in, I have done this about five times myself for other people,,,I'm saying this is the car that forum member mikecatts was building some time back, there is a thread some were about it.
Rego want be a problem as long as the inner guard number is from a 6cyl 2 door.
Keep us posted
Cheers gong
