Handbrake adjustment
Posted 19 June 2020 - 05:39 PM
Posted 19 June 2020 - 06:47 PM
Think you can you wind that barrel adjuster at the bottom between the shoes out to reduce the need for so much cable adjustment
Don't know about the little Torana brakes but on the LX there is a slot in the backing plate you can put a screwdriver through to wind the barrel nut
Good luck,
Posted 19 June 2020 - 09:11 PM
Posted 19 June 2020 - 09:56 PM
Yeah, back off your cable adjustment till its loose.
Adjust the brake shoes.
Then readjust your cables.
Posted 20 June 2020 - 10:17 AM
You've got the self adjusters fitted to the rear drums. Forward and reverse the car several times to self adjust the rear brakes then adjust your handbrake.
