K frame assembly lubrication
Posted 22 June 2020 - 07:47 PM
Should the upper control arm pivot rods be greased where the bush sits on them? I assume that the pivot rods should be able to rotated within the bush so that the bush doesn't move in the control arm instead.
On a side note, my upper control arm bump stops pushed in to my freshly painted control arms easily by hand with a bit of rubber grease.
JD
Posted 22 June 2020 - 08:34 PM
Posted 23 June 2020 - 05:26 AM
All the bushes are new Makay rubber ones.
Posted 23 June 2020 - 09:14 AM
Hi James ,Just a quick tip, I put a bit of never seize on the bar only to make it easy to replace the bushes next time. As mentioned above the bushes shouldn't move on the bar or within the control arm, its the rubber flexing that does all the work. leave the control arm pivot/mount bar end nuts loose and tighten them when the car is on the ground, full kerb weight and at ride height is best. Don't tighten the nuts when suspension is in droop (up on stands). Tightening the nuts up in the air will cause the bushes to be loaded up when droped on the ground further twisting the rubber bushs. The extra movement when driving will cause further twisting and the extra loading will cause premature damage to the rubber bushes.
Posted 23 June 2020 - 12:09 PM
Posted 27 June 2020 - 10:46 AM
The workshop manuals don't seem to show this torque setting because taking these bolts out wouldn't be done in normal services of the suspension but only in a restoration.
Thanks.
