Lc heater fan motor is there an after market one available
14 replies to this topic
#1 _Pborg8_
_Pborg8_
Posted 21 July 2020 - 05:38 PM
Hi Guys re vamping the heater box in the Lc  found electric motor on the fan to be sized
 has any one found a replacement after market one . Or sa siliar out of another car make that is similar in size
#2 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 21 July 2020 - 08:54 PM
I started looking myself. I found lots online that looked similar but never took it any further.
I remember looking at commodore and even some Imports on eBay.
Good luck at let us know how you go.
#3 _Pborg8_
_Pborg8_
Posted 22 July 2020 - 05:40 AM
Will do
#4 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 22 July 2020 - 01:08 PM
Haven’t seen a fan motor for a while but couldn’t you split it, replace bearings as I’d be surprised if it was burnt out?
#5 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 22 July 2020 - 03:01 PM
It shouldnt be a huge drama getting it running again.
Start pulling it apart and give it good washes with penetrene as you go.
Leave it for a day or so to soak.
Newer motors though will give more air especially if you use the modern blades.
You could possibly get an entire heater aircon unit from a Commodore fairly cheaply.
Axistr (Lenny) our power steering guru used the heater and aircon unit out of a Hilux in his big Toranas
Rob
#6 Smiling
Smiling
  • 15 posts
  • Car:LJ 4 door
Posted 29 April 2023 - 11:29 AM
Hi Gents,
like Pborg8 i am refurbishing a heater assembly and blower motor.
I have a good commutator and bits & pieces which i am fitting to my blower motor case (as my commutator, brushes etc are junk).
The motor spins freely when i put 12v to it, so is in reasonable shape.
My questions are:
Can or should the commutator be cleaned?
Is there any type of lube that should be used on the shaft when the bearings/bushes are installed?
Cheers,
Luke
#7 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 29 April 2023 - 03:02 PM
Commutator can be skimmed to clean it up, then the insulation between the segments needs to be under cut a little.
Without having one in front of me they generally have brass/bronze bearings.
They are known as self lubricating.
A smear of grease is all I would ever use on one as any excess grease will likely get into the motor, collect crap and then cause issues.
I would likely soak the bearings in oil for a bit then clean them up before reassembly.
Rob
#8 Smiling
Smiling
  • 15 posts
  • Car:LJ 4 door
Posted 29 April 2023 - 07:12 PM
Thanks Rob,
i'll follow that advice when i reassemble for the last time. (I have had it apart and back together with various pieces, trying to find
the bits that work the best.)
Is there a trick to getting the bearing retainer/support out of the base, as i cant seem to get the base bearing back into the retainer.
I think i need to put the bearing in, then fit the retainer.
Any ideas?
Cheers Luke
#9 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 30 April 2023 - 01:09 PM
Thanks Rob,
Any ideas?
Cheers Luke
Any pics you can show me so I can get an idea?
Havent played with one for a long time, so memory cant be relied upon for specific ideas.
Ive got an LX one floating around somewhere. It should be similar but would have to find it then pull it apart.
Pics would make it easier.
Rob
#10 LCK186
LCK186
  • 404 posts
  • Car:71 CK
Posted 30 April 2023 - 07:20 PM
Hi theres 0ne on ebay cheep look it up.
#11 Smiling
Smiling
  • 15 posts
  • Car:LJ 4 door
Posted 01 May 2023 - 06:59 PM
I'm guessing the one on ebay doesn't work, anyhow
I'll get some pics up shortly so you can see what i'm on about. (i'm not much good on the computer or phone, it might take me a day or two :D ) ,
#12 S pack
  • 15,745 posts
Posted 01 May 2023 - 08:07 PM
Thanks Rob,
Any ideas?
Cheers Luke
How did you get the bronze bearing out without removing the retainer? From memory the motor casing is staked in three? places to prevent the bearing retainer from dislodging. I tried to get one out once and gave up for fear that I would wreck the retainer.
Edited by S pack, 01 May 2023 - 08:07 PM.
#13 Smiling
Smiling
  • 15 posts
  • Car:LJ 4 door
Posted 04 May 2023 - 09:17 PM
The bearing came out of the retainer quite easily when i separated the two halves of the motor as it was seized on the commutator shaft.
The bearing retainer flexes it's 6 retaining tabs one way (to get the bearing out) but not the other way to refit the bearing.
There are 4 lugs (about 2x2mm in size) keeping the retainer in place. I started grinding two of the lugs with a die grinder, but also was worried about destroying the retainer so didn't go too hard.
(I might just need to harden up, and have a real go at it!)
In one of my bases where the retainer is rusted and broken, i can fit the bearing in when i joint the motor back together but it obviously doesn't holden the bearing in the centre, so the motor is noisey when turned on.
I am trying to load some photos, fingers crossed
Cheers,
Luke
IMG_0357 | Smiling | Flickr
IMG_0358 | Smiling | Flickr
IMG_0356 | Smiling | Flickr
#14 Rockoz
Rockoz
  • 4,055 posts
  • Name:Rob
Posted 05 May 2023 - 03:01 PM
Turn the bearing 90 degrees from the way it should sit and it should press in without much drama.
Then rotate it to where it needs to be.
From memory they were considered to be self centreing.
Rob
#15 Smiling
Smiling
  • 15 posts
  • Car:LJ 4 door
Posted 05 May 2023 - 05:18 PM
Thanks Rob, Easy when you know how!!
It took me about 2 minutes once i rotated the bearing. The motor is back together, and it runs nicely without the racket.
One more job ticked off, Much appreciated input from the forum, Cheers, Luke :D
